February 12, 2026, 11:52:12 AM *
Author Topic: U joints - back ordered  (Read 5263 times)
Lyle Laun
Calgary, Ab
« on: August 14, 2016, 08:04:39 AM »
I'm looking for a new U Joint but it seems they are on back order. Does anyone know of a replacement or a work around solution ?
Lyle
Get out & Ride !!
98 Black "Rat Rod" Standard
99 Green/Silver Interstate
« Reply #1 on: August 14, 2016, 08:21:07 AM »
BigBF recently posted that he ran into that problem.  Let's hope it's temporary.
da prez
Wilmot Wi
« Reply #2 on: August 14, 2016, 08:29:55 AM »
  I have a good used one in stock. I found a new one and am willing to part with my spare if you need it.
                                      da prez
Lyle Laun
Calgary, Ab
« Reply #3 on: August 14, 2016, 08:50:43 AM »
Thanks for the offer da Prez. I'm not in a bind yet but am replacing the shaft and pinion cup on one of my bikes and thought I'd also do the u joint at the same time.
Lyle
Get out & Ride !!
« Reply #4 on: August 14, 2016, 03:45:13 PM »
Same here, I've a spare, and it's already in Canada.
If you need it, you pay the shipping, and buy another spare, so we have one on hand. No rush, next big trip will be to Valhalla/InZane 2017.
I'll be driving up to Edmonton Sept 23, and a sister-in-law lives in Calgary. Could arrange something if you are doing things on the cheap (I know I try to not spend where I don't need too).
Dirty Dave
Montreal, Canada
« Reply #5 on: August 14, 2016, 04:34:35 PM »
Hondas and U-joints. Hmmmm. We should all keep our eyes open these days for replacements.
I've stocked up with spares for my 79 Wing (no longer available) and my 97 Valk. eBay will eventually come through........
It's weird being the same age as old people
« Reply #6 on: August 14, 2016, 04:51:52 PM »
Yeah, last time they ran out (lost supplier), when they came back, the price nearly doubled.  I hope that doesn't happen again.
Grumpy
Tampa, Fl
« Reply #7 on: August 14, 2016, 08:33:46 PM »
Just checked service honda, shows them in stock $137
Roidfingers
Tuscaloosa, Alabama
« Reply #8 on: August 15, 2016, 12:15:12 AM »
partszilla has them for 133
Lyle Laun
Calgary, Ab
« Reply #9 on: August 15, 2016, 06:55:08 AM »
I will check Service Honda. I've already got an order in at Partzilla and Procaliber and they are both back ordered
Lyle
Get out & Ride !!
Beardo
Regina, Saskatchewan Canada
« Reply #10 on: August 15, 2016, 08:12:13 AM »
This thread got me thinking I should find a spare, my Valk is on its original u-joint with 75,000kms on it.
Called my local Honda dealer(Canadian), parts person said the original part ($140) is discontinued and a new one is available in September for $263!!
Looks like Jess from VA was exactly right.
fantsybikr
O HI O
« Reply #11 on: August 15, 2016, 05:03:31 PM »
Does anyone know..can the u-joint be rebuilt? Are there any Goldwings that use similar u-joint?
VRCCDS 0252
  VRCC   26284
 GWRRA 329832
« Reply #12 on: August 15, 2016, 05:10:27 PM »
People started rebuilding them (with I don't know how much success)
last time this happened.
1500 goldwings use the same ujoint.
fantsybikr
O HI O
« Reply #13 on: August 15, 2016, 05:31:43 PM »
I would be interested in information on the joint needed to rebuild with..if it could be done successfully..sounds like there is a need
VRCCDS 0252
  VRCC   26284
 GWRRA 329832
fantsybikr
O HI O
« Reply #14 on: August 15, 2016, 06:05:41 PM »
from what i can find it would be easier to the moon than rebuild the joint, which seems crazy to me, honda had a bastard size joint made for their cycles? i guess thats one way of making sure people have to buy from you for their parts
VRCCDS 0252
  VRCC   26284
 GWRRA 329832
Woton
Central North Carolina
« Reply #15 on: August 16, 2016, 03:29:21 AM »
I'm in the market for one of these as well - not critical, but I know it is coming... Lips Sealed
Would appreciate it if someone currently looking would report the actual receipt of a new u-joint from one of the vendors.
Would rather avoid the backorder game. Sad
"Ride Smart - Ride Safe"
Tasco_1
High River, Alberta
« Reply #16 on: August 16, 2016, 07:04:58 AM »
Interesting thread. I'm definitely going to order one from Honda.  It's interesting that not even a transmission supply house can come up with a solution.  Maybe it's possible to build a new shaft with common parts, or even modify the original.  This is my first post, and a newbie to the the Valkyrie, so hopefully I don't sound to ignorant.  But just thinking out loud.
« Reply #17 on: August 16, 2016, 10:41:30 AM »
its been done before. Think it just didn't turn out that feasible.
« Reply #18 on: August 16, 2016, 05:22:29 PM »
It took a while, But I think I found the post on the serviceable u-joint.
http://www.valkyrieforum.com/bbs/index.php/topic,28837.0.html
I read some other posts, there was talk of the joint being used, being the wrong one, cup was .002 small, and was therefore loose and would wear out the yoke. Might need to verify everything being said in the rebuild.
I believe the issue was that the rebuild was costing more than buying a new u-joint when they became available again, so it was no longer worth pursuing.
Evie
Naperville, IL
« Reply #19 on: August 17, 2016, 03:37:16 AM »
I had a U-joint go out at 138K.   Ordered one from pro caliber July 5th and it's still on backorder.
I ordered one on e-bay....used and replaced, but still waiting on the new one from pro caliber.
When I get the new one I'll do the replacement during one of my tire changes and sell the used part.
3W-lonerider
Shippensburg Pa
« Reply #20 on: August 17, 2016, 06:58:59 AM »
i had one of those rebuildable joints. lasted less than 2000 miles before it grenaded. the cups blew out of the yokes.
Paladin528
« Reply #21 on: August 18, 2016, 05:32:36 AM »
I am waiting for a back ordered u-joint here in Toronto. Partzilla says Honda will have it to them on August 25. I sure could use a replacement now as mine is pooched and I do not want to shove a used one in there when I just replaced half of my rear end.
If anyone has a NEW spare I would gladly send you my new one when it arrives just to get me back on the road
Woton
« Reply #22 on: August 18, 2016, 05:44:47 AM »
Bummer, Paladin.  Hope someone out there might be able to help you get rolling again. Kiss
Guys and girls, let's post when someone receives a shipping confirmation from one of these online vendors.
Partzilla is my go-to online vendor and I'll be checking with them next week myself.
Paladin528
« Reply #23 on: August 18, 2016, 06:06:48 AM »
I spoke to partzilla this week. I ordered the u-joint before I went on vacation overseas. I called to see why it hadn't shipped yet.  They told me it was on back order and their date from Honda was Aug 25!delivery to them. So another week after that and I should have it.
Local Honda dealer cannot get one either.
Roidfingers
Tuscaloosa, Alabama
« Reply #24 on: August 23, 2016, 06:17:15 AM »
I ordered one on aug 14, from Partszilla and was suppose to ship aug 18. Never did. I got on their Live Chat just now and he told me it showed on back order and no date from Honda when it would be available. But, as I'm inquiring about the charge, he says "One moment" Comes back and says it is now showing in stock and it will ship out today. So I'm waiting on an email with a tracking number. Maybe it will happen. Those of you with back ordered ones may want to check.
Paladin528
« Reply #25 on: August 23, 2016, 07:59:20 AM »
Just hung up with Partzilla.  No estimate from honda at this point.
Paladin528
« Reply #26 on: August 23, 2016, 08:16:47 AM »
LMFAO.  I hng up with Partzilla and called honda direct who told me Aug 28 - Sep 6.  I went back into Partzilla then looked at my order and it shows SHIPPED with a Tracking Number.
Lyle Laun
Calgary, Ab
« Reply #27 on: August 23, 2016, 08:18:35 AM »
Partzilla just told me this morning that the 2 ujoints I have on back order are now in and getting prepped for shipping.
We'll See...
Lyle
Get out & Ride !!
Woton
« Reply #28 on: August 23, 2016, 09:03:58 AM »
 2funny  LMAO!!!
Looks like I'd better modify my last post back to my original - asking folks to inform the board when they actually RECEIVE a new u-joint from one of these online suppliers!!!!
Lyle Laun
Calgary, Ab
« Reply #29 on: August 23, 2016, 02:41:29 PM »
Not only did Partzilla tell me they are shipping my ujoint, I also have one on backorder from Procaliber and just rec'd an email from them that they too are shipping the ujoint.
I'm starting to believe that the ujoint drought may have ended !
Lyle
Get out & Ride !!
Roidfingers
Tuscaloosa, Alabama
« Reply #30 on: August 23, 2016, 02:47:18 PM »
Only got 47000 on my std but glad I got a tracking number and one on the way. Never know.
pancho
Bonanza Arkansas
« Reply #31 on: August 23, 2016, 04:50:45 PM »
Yeah, it can happen, I had one go at about 50K.
sdv003
Prescott Valley, AZ
« Reply #32 on: August 23, 2016, 07:56:32 PM »
I have a tracking number as well from procaliber
Woton
« Reply #33 on: August 24, 2016, 04:56:02 AM »
It's raining u-joints!  Grin
« Reply #34 on: August 24, 2016, 05:20:20 AM »
Well actually it's just raining tracking numbers.  Grin
« Reply #35 on: August 24, 2016, 06:23:17 AM »
You all do realize that you're contributing to if not creating the situation?  U-joints are back-ordered primarily due to a lot of people panicking and buying backups if not multiple backups.  There are enough U-joints out there now to serve all the Valkyries still on the road but they are in private hands.  So long as people keep snatching them up when they become available until they are no longer available they will continue to appear to be rare and continue to become more and more expensive.
While a thread such as this one provides the service of alerting people to a possible situation, it unfortunately exacerbates that very situation.
Roidfingers
Tuscaloosa, Alabama
« Reply #36 on: August 24, 2016, 06:56:32 AM »
Well I have one on truck for delivery and will now have my back up when needed. No more ordering for me.
Woton
« Reply #37 on: August 24, 2016, 07:50:43 AM »
If anyone on the thread receives more than one new u-joint in this process, and does not want the extra one, please shoot me a personal message.
Lyle Laun
Calgary, Ab
« Reply #38 on: August 24, 2016, 08:45:37 AM »
Willow:
I agree with you totally but I've got 3 Valks that are getting up in mileage and my bikes do a lot of long distance rides. I'm not excessive in regards to preventitive maintanance but have come to believe in doing pm on alternators, wheel bearings, etc.
roadside breakdowns on long trips aren't much fun. Motel parking lots should be for drinking beer, not repairing bikes.
Lyle
Get out & Ride !!
h13man
Indiana NW Central Flatlands
« Reply #39 on: August 24, 2016, 08:50:28 AM »
Available here http://www.powershondaparts.com/oemparts/a/hon/506cb61ef870023420a4174e/swingarm
I done a "checkout" and no issues as far as availability but....
