February 12, 2026, 09:44:02 AM *
Author Topic: Front wheel beatings  (Read 1178 times)
NighthawkVTX
Gainesville, Fl
« on: August 20, 2016, 04:29:43 PM »
Anyone have an idea how much a new set of front wheel bearings run for a 99IS?
If at first you don't succeed, then perhaps skydiving isn't for you
« Reply #1 on: August 20, 2016, 04:39:15 PM »
Why you want to beat your front wheels?
http://partstream.arinet.com/Mobile/YCxPvLcJG5QOnJ2AnsnPxTlIXadGEfkUBhuScpMaLXkjIVa--N45hGf-3hQibJSxTetRrmX6A542lnP0Z0ohVzMrFlZR2VG3pzyS5jb8b8uMKhHfTijZFuHdHTOoi1_b0.html#/Mobile/9j87GMU_ebe6GRTt3efneVXg5PnanX_51AY-d-nXWFeYlhPCjJV9SySSSttpHnE48G-183N9EaYj0C8s93aL99EQ1rv0XTzThg-kSMK1g701.html
« Last Edit: August 20, 2016, 04:41:14 PM by Bighead » Logged
« Reply #2 on: August 20, 2016, 04:45:09 PM »
I've always thought Timkens were good.
http://www.ebay.com/itm/6204-2RS-TIMKEN-Ball-Bearing-20x47x14-mm-deep-groove-ball-bearing-/221867355472
« Reply #3 on: August 20, 2016, 05:57:54 PM »
They don't cost enough to justify looking for cheap replacements.  Get good ones, put them in correctly and D don't worry about them for years.
NighthawkVTX
Gainesville, Fl
« Reply #4 on: August 20, 2016, 06:18:21 PM »
Im noticing a slight wobble at about 45mph. I know that was a sign of a need for replacing bearings on the vtx 1300
« Reply #5 on: August 20, 2016, 08:27:34 PM »
        How many miles you have on the clock? I replaced the rears at 93000+ miles and the fronts are still good at 122000+ miles. Look at your shock bushings first. And how are the upper fork bearings? RIDE SAFE.
h13man
Indiana NW Central Flatlands
« Reply #6 on: August 21, 2016, 05:16:49 AM »
At my local power motion dealer, $11 ea. for NTH. #62042RS. This is for 98' and newer.
« Last Edit: August 23, 2016, 08:11:05 AM by h13man » Logged
keithi
« Reply #7 on: August 22, 2016, 05:33:41 AM »
MasterPro  PT204FF  from O'Reilly's Auto Parts.....$5.99 ea...just put two on mine.... cooldude
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #8 on: August 22, 2016, 06:06:55 AM »
http://www.procaliber.com/oemparts/a/hon/506c2ee8f870023420a31b0f/front-wheel
