February 12, 2026, 09:44:52 AM *
Author Topic: 1999 Standard , starts but only runs on full choke  (Read 951 times)
dconstruct55
Phoenix AZ.
« on: August 21, 2016, 01:44:50 PM »
Going to put my 1999 Valk standard up for sale. Been sitting for about 2 months, battery was dead so I charged it up and went out to start it after placing the ad on Craigslist. Starts on full choke and seems to idle fine, but when I go to shut down choke she dies. Starts right back up and just does the same thing. Never had any issues with her before and have not done anything besides charging the battery. I really don't have much time lately to ride or work on her, am a carpenter, NOT a mechanic, any ideas?
« Reply #1 on: August 21, 2016, 01:54:07 PM »
Sounds like your jets are clogged from sitting. Some have had luck with fuel cleaners. I didn't, ended up having to remove carbs and clean them.
Harryc
Sebastian, Fl
« Reply #2 on: August 21, 2016, 02:10:19 PM »
Get a bottle of Seafoam and put half of it in a full tank of gas. Idle it for several minutes on choke if you have to. Let it sit overnight or longer. If that doesn't work you'll have to pull the carbs to clean them.
dconstruct55
Phoenix AZ.
« Reply #3 on: August 21, 2016, 02:18:02 PM »
Thanks guys,
I always try to use Chevron about every third tank to avoid this, guess I just let her sit too long.
Just want everyone to know, am not abandoning the Valk world, I have a very nice '99 Tourer I keep at my cabin in Prescott AZ.
« Reply #4 on: August 21, 2016, 03:34:19 PM »
Thanks guys,
You should come to the BBQ in October. It's on the AZ & SoCal chapters.  cooldude
The problem I have found with the gas is that even though it's got Techron in it, it's still got the alcohol mix. If you are not going to ride on a consistent basis search for straight gas.
dconstruct55
Phoenix AZ.
« Reply #5 on: August 21, 2016, 04:51:40 PM »
Thanks MH,
You probably know how hard it is to get out in 100+ degrees. I will look into the BBQ, keep me posted if you have the time.
« Reply #6 on: August 21, 2016, 05:01:24 PM »
Thanks MH,
Here is a link to the event. There are several from the Phoenix area coming. I'm sure you could hook up with them.
http://www.valkyrieriders.com/socal/John%20G%27s%20BBQ/Details.htm
dconstruct55
Phoenix AZ.
« Reply #7 on: August 21, 2016, 06:13:12 PM »
Thank you!
I will be signing up!
