February 12, 2026, 09:44:40 AM
Wiring Issue - Need Help
Topic: Wiring Issue - Need Help (Read 733 times)
ohno3kids
August 25, 2016, 08:13:28 AM »
Last weekend, I replaced the starter switch and rubber grommet on the front blinker on my '97 1500C. I had to disconnect/reconnect the blinker wiring to replace the grommet. New switch works great, and my front blinkers "blink". But, my tachometer and neutral light quit working, and my front blinkers don't stay on with the front light. I checked wiring behind the headlight, and it all seems intact. Any advice, before I take it to the shop? Thanks
Re: Wiring Issue - Need Help
August 25, 2016, 08:20:38 AM »
Undo everything you did and do it over making sure things are right, check all the fuses and bulbs. Sometimes cramming everything back into the headlight shell causes a loose connection, double check all of them
big poppa pump
San Antonio, TX
August 25, 2016, 09:17:20 AM »
Check your 10A fuse.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
