February 12, 2026, 09:44:11 AM *
Author Topic: I broke it - Can it be fixed?  (Read 1287 times)
Gideon
Indianapolis, IN.
« on: August 29, 2016, 12:13:01 PM »
I broke the knob and shaft off the side of my speedometer.  Sad
I just filled the gas tank, and started to turn the odometer back to zero when the knob and shaft broke off.
Has anyone else done this?
How did you fix it?
Suggestions please?
Roidfingers
Tuscaloosa, Alabama
« Reply #1 on: August 29, 2016, 12:28:55 PM »
Part number 10.
http://www.bikebandit.com/oem-parts/2001-honda-valkyrie-deluxe-gl1500cd-speedometer/o/m151313sch103648
« Reply #2 on: August 29, 2016, 07:23:31 PM »
I was just spinning mine today and thinking Damn this this is an antique cooldude
Gideon
Indianapolis, IN.
« Reply #3 on: August 30, 2016, 02:15:15 PM »
Thank you Roidfingers. Installing the new knob looks simple enough.
Barry you are correct. However, I am sure you like me are not ready to give up on these great machines.
Roidfingers
Tuscaloosa, Alabama
« Reply #4 on: August 30, 2016, 04:13:57 PM »
Yes very small precision phillips head screw driver. Take out old install new. Screw is small. if its broke on the inside of cover then I would magnetize the screw driver so you don't loose it inside the housing. But if it does fall in. Just remove the cover. That's simple too.
Gideon
Indianapolis, IN.
« Reply #5 on: August 31, 2016, 08:08:24 AM »
The small screw is still in the portion that broke off.
With the screw being so very small and my hands being so big, I ordered a new one when I ordered the knob.
Thank you for your input.   Smiley
