February 12, 2026, 09:44:36 AM *
Author Topic: Brake bleeder check valve  (Read 977 times)
Alberta Patriot
« on: September 02, 2016, 08:18:51 AM »
I was considering speed bleeders for flushing my brake and clutch lines, but I got to thinking...could I use an inline check valve with barbed fittings midway in the clear plastic tube that slips onto the bleeder valve instead??
« Reply #1 on: September 02, 2016, 08:30:51 AM »
There's a guy who uses a speed bleeder as a check valve in his tube that
fits onto his regular bleeder valves, so, I'd guess you have an idea worth
trying....
I have speed bleeders, and find them to work well. When you drain the
whole system, you have to prime the system a little before the speed
bleeders will start doing their thing, but it is not a problem...
Alberta Patriot
« Reply #2 on: September 02, 2016, 08:39:22 AM »
Never thought of using a speed bleeder...good plan...so if my idea doesn't work out I can still use the speed bleeder on the bike...I would like to do my truck and car as well if it works.
« Last Edit: September 02, 2016, 08:50:36 AM by 7th_son » Logged
