February 12, 2026, 10:13:34 AM *
Author Topic: Valkyrie interstate intercom connector layout.. not the din,the other end...  (Read 848 times)
Memor86
Tampico, Mexico
« on: September 06, 2016, 08:26:46 PM »
Help guys, I'm looking for info about the layout on the passenger intercom connector, not the 5 pin din connector. I mean the square connector on the radio unit where the cable with the 5 pin din connector on the other end connects to the bike.. I found a pic online from a goldwing bike but the connector is a female type and the Valkyrie has a male connector and I am afraid that it's not the same layout.
The picture I attached is supposed to be from a Valkyrie, I'm talking about the red connector. Which my bike does not have, I managed to find the same connector and I want to wire it with the stock layout.
Any ideas?
« Reply #1 on: September 06, 2016, 09:20:25 PM »
I'm sure that info is in the Service Manual. You can DL the PDF file from Dag's site.
http://valkyrienorway.com/download.html
Page 20-11 (page 442). Shows the wire colors. Then says,
Front : Remove the left from inner fairing (page 2-5 .
Rear: Remove the seat (page 2-21 and right side cover (page
2-31 .
Disconnect the headset junction wire SP (red) connector and
remove the junction wire.
Check for continuity between the same color wire terminals of
the 6P (red) connector and junction connector.
There should be continuity.
I don't know which one is the junction connector, but I'm sure you can fine it.
I forget, but why are you looking?
« Last Edit: September 06, 2016, 09:26:15 PM by gordonv » Logged
Joe Hummer
Arnold, MO
« Reply #2 on: September 07, 2016, 05:29:29 AM »
This may help you out...
http://www.rattlebars.com/valkfaq/schematics/rpage09i.html
you are looking for the wiring of the Passenger Headphone Jack in the top center of the schematic.
Joe
1999 Valkyrie Interstate
