April 01, 2026, 04:57:46 PM *
Author Topic: Gauges on Interstate  (Read 1486 times)
mmgoatman
2000 Valkyrie Interstate
Ganado, Texas
« on: September 09, 2016, 08:12:32 AM »
Wanted to be able to monitor engine a little more so I added some gauges.
Oil pressure, volt meter, and water temperature.
Auto meter triple gauge set #2391 -- comes with sensors.
Water in top radiator hose, oil sender on left of engine behind lower radiator hose.
Radiator hose adaptor 28 mm with 1/8 npt threads.
20 mm x 1.0 oil adaptor with 1/8 npt threads.
Everything works great and all for just a little over $100.00
http://www.mmgoatranch.com/wpimages/wpcedff539_05_06.jpg
http://www.mmgoatranch.com/wpimages/wpc9c877a8_05_06.jpg
http://www.mmgoatranch.com/wpimages/wp07343c4d_05_06.jpg
Ramie
2001 I/S St. Michael MN
« Reply #1 on: September 10, 2016, 11:59:41 AM »
They look nice, how about a link or manufacturer
mmgoatman
Ganado, Texas
« Reply #2 on: September 11, 2016, 11:46:57 AM »
http://www.egauges.com/ProductDetails.asp?ProductCode=ATM-2391&gclid=CJjj7o-4xM4CFYgAaQod0_8EkA
Ramie
« Reply #3 on: September 12, 2016, 07:15:09 AM »
Thanks goatman
mmgoatman
Ganado, Texas
« Reply #4 on: September 12, 2016, 07:39:09 AM »
These gages are designed to mount at a slight angle. So if mounting them straight on you may have to trim the brackets a little. I used tin snips to trim them. I also mounted them into pvc pipe adaptors (painted black). U-bolts on the handlebars and some angle iron to mount to.
Here is a link to radiator hose adaptor:
http://www.ebay.com/itm/US-28mm-Water-Temp-Gauge-Radiator-Hose-Sensor-Aluminum-Adaptor-Clamp-Silver-/262407732874?vxp=mtr&hash=item3d18b83e8a
here is a link to oil pressure adaptor:
https://www.denniskirk.com/koso-north-america/blue-oil-temperature-adapter-bg302010.p4901107.prd
