February 12, 2026, 10:13:50 AM *
Author Topic: Truck stacks  (Read 1100 times)
tx blue
« on: September 11, 2016, 01:35:15 PM »
I have a set of 4" truck stack's that come out to the end of my interstate bags,they have the stock piggies there seems to be a drone at high way speed that is a little bothersome. If I was to extend the piggies out closer to the end of the truck stack would that tone down the drone noise.
Phil
« Last Edit: September 12, 2016, 03:19:32 AM by tx blue » Logged
« Reply #1 on: September 11, 2016, 02:47:14 PM »
Yes, some even extend them out of the stacks which looks pretty cool  cooldude
« Reply #2 on: September 11, 2016, 03:33:35 PM »
a drone usually means some of the EPA baffles have been drilled through.
contact MarkT, I think he has a setup that adds another set of the OEM small resonators to the piggies.
« Reply #3 on: September 11, 2016, 04:48:50 PM »
The "period" is the second key to the left of the "shift" key at the bottom right of the keyboard.  Wink
Cracker Jack
« Reply #4 on: September 11, 2016, 07:23:35 PM »
thats mean tickedoff
« Reply #5 on: September 11, 2016, 09:27:34 PM »
Period or comma?
Do you have the original stock length piggies left, or are they cut back? The following is what was referred to, to fix cut piggies.
http://www.valkyrieforum.com/bbs/index.php/topic,38448.msg388067.html#msg388067
But if it is just the lengthened truck stacks that is causing the drone because the piggies end well within from the end, then there are posts about getting copper pipe and adding it on.
tx blue
« Reply #6 on: September 12, 2016, 03:22:41 AM »
 2funny
Kunkies
Charlotte, NC
« Reply #7 on: September 12, 2016, 03:35:13 AM »
I cut off my "piggies", and drilled through the last two baffles and experienced exactly what you describe; droning.  These solved my problem, and easy to install. . .
http://shopping.rexmar.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=161100&Category_Code=silencers-inline-insert
Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
« Reply #8 on: September 12, 2016, 05:50:06 AM »
I cut my piggies before the bends and then extended them so they stick out of the truck stacks, I like the look better than the piggies lined up and she is super quiet with no drone.
« Reply #9 on: September 12, 2016, 07:19:28 AM »
I have a set of 4" truck stack's that come out to the end of my interstate bags, they have the stock piggies. There seems to be a drone at high way speed that is a little bothersome. If I was to extend the piggies out closer to the end of the truck stack would that tone down the drone noise?
Phil
Phil, just ribbing you a bit but never questioning you. More to the point, you've been given good advice on the cause and correction of the drone. If the stack extends well past the piggies it does have a tendency to create an annoying drone, the sound wave kinda bounces around inside the hollow stacks.  cooldude
tx blue
« Reply #10 on: September 12, 2016, 03:50:43 PM »
As alway's thanks for everyone's help.
Phil
