February 12, 2026, 10:13:48 AM
clutch possible problem???
Topic: clutch possible problem??? (Read 869 times)
VALARIE
September 11, 2016, 01:46:57 PM »
Hello everyone,,, just flushed clutch and brakes, fluid pretty gooey in the clutch, took awhile but got it done, brakes are much better,,, BUT... I feel now that my clutch lever must now be let out more than before before she moves, not quite all the way out but close, say quarter inch?? It seems to shift up and down ok but not as much peddle??? thanks,,,,
Re: clutch possible problem???
September 11, 2016, 02:01:35 PM »
did u take the slave cylinder apart and clean it out also? bleeding does not do the job.
VALARIE
September 11, 2016, 04:24:57 PM »
no, is this clutch handle position ?normal
longrider
Vernon, B.C. Canada
September 11, 2016, 04:33:04 PM »
Mine is the same. Only have to pull maybe 3/4 inch to have it start to disengage
VALARIE
September 11, 2016, 04:43:22 PM »
so, longrider my newly flushed clutch seems to be NOW behaving the same as yours? I HAVE heard that Valkyries clutch handle do let out a ways before travel
VALARIE
September 11, 2016, 05:17:35 PM »
well, I'm reading a lot of guys that have had a similar experience AFTER flushing master and xing fluid,, I understand that all hyd clutches engage/disengage very near the "all out" lever position and they should engage/ disengage in first 1 to 2'' from fully extended OUT, as mine is NOW doing AFTER the above maint was done , so...I guess I need to get used to it...it sounds like its NOW working properly
