February 12, 2026, 05:12:37 PM
Fuel / Air mixture screws?
Topic: Fuel / Air mixture screws? (Read 1391 times)
Roidfingers
Tuscaloosa, Alabama
September 16, 2016, 01:41:52 PM »
Pulling my carb bank it next few days. Want to cut the slots in the mixture screws in order to adjust easier. Also do some cleaning. I've thought about buying new ones, But for 6 of them it's 85 bucks for oem. Anyone know of aftermarket match? Or have used any others with success? Thanks
Re: Fuel / Air mixture screws?
September 16, 2016, 05:32:05 PM »
they are used on many honda bikes. go to a parts house and u can see all bikes the part fits. they really don't wear, why change?
Tejas
Cy-fair, Texas
November 17, 2016, 01:16:52 PM »
If you still need carb gaskets/parts and tools, look at Red Eye Technical Services online. I got mine from them. I also got an inexpensive fuel/air mixture tool. All worked and the price was great compared to Honda.
Brian
Monroe, NC
November 18, 2016, 03:12:45 AM »
Quote from: Tejas on November 17, 2016, 01:16:52 PM
Yep, the tool made the job very easy. I say replace them after seeing what shape mine was in.
November 18, 2016, 05:08:03 AM »
I use the honda tool, no need to cut slots.
it has a flexible spring head. been using it for yrs.
07MMA-MT3010B WRENCH PILOT SCREW
Attic Rat
VRCC # 1962
Tulsa, OK
November 19, 2016, 08:47:59 AM »
Don't cut the slots you can buy the tool about anywhere for around 6.00
Reply #6 on:
November 19, 2016, 10:03:15 AM »
Quote from: Attic Rat on November 19, 2016, 08:47:59 AM
I looked, but couldn't find it.
Suggestions, or the name they call it so I can do a search?
Attic Rat
VRCC # 1962
Tulsa, OK
Reply #7 on:
November 19, 2016, 12:26:25 PM »
Here is a link to amazon that carries it. This is what I use on a 1/4 socket when I do them on the bench
https://www.amazon.com/Motion-Pro-Degree-Driver-D-Shaped/dp/B003CMWC4U/ref=sr_1_2?ie=UTF8&qid=1479588321&sr=8-2&keywords=d+shaped+carburetor+tool
