February 12, 2026, 11:52:05 AM *
Author Topic: Smoke while engine braking  (Read 1622 times)
Memor86
Tampico, Mexico
« on: September 16, 2016, 08:22:29 PM »
I'm riding trough Twisties  and been using a lot of engine braking, friends behind me told me my bike was smoking while engine braking, is that OK?
WintrSol
Florissant, MO
« Reply #1 on: September 16, 2016, 08:26:07 PM »
Probably oil smoke, which is usually from oil leaking past the valve guides. You may need new valve stem seals, #1: http://www.partzilla.com/parts/search/Honda/Motorcycle/1998/GL1500CT+A/CAMSHAFT+%2B+VALVE/parts.html
« Reply #2 on: September 16, 2016, 08:28:32 PM »
I haven't seen any Valkyries do that. But I agree with WintrSol. It's probably worn valve guides.
BonS
Blue Springs, MO
« Reply #3 on: September 17, 2016, 05:09:51 AM »
I have seen it on a close friends Valk. He had a puff on startup and after deceleration. We went on a trip to Colorado and he found his crankcase to be a quart low along the way. I replaced the valve stem seals and the problem is gone. That was about a year and a half ago and all is well. It's not a bad job with the right tool but it is tedious. This is the link to my write up is here http://www.valkyrieforum.com/bbs/index.php/topic,76208.0.html
« Reply #4 on: September 17, 2016, 07:46:38 AM »
only use new viton/teflon seals, last longer and cheaper
http://www.ebay.com/itm/HONDA-VITON-VALVE-SEAL-12209-422-005-/300888458966?hash=item460e5986d6:m:mNtN5Q9HTJVBGbTz1SBK6bA&vxp=mtr
« Reply #5 on: September 17, 2016, 08:11:40 AM »
Basic auto Tech. Should be the same on our engines.
Blue smoke on acceleration, oil going by the rings. Worn rings and/or cylinders, or too much oil.
Blue smoke on deceleration, the "vacuum" action of the cylinders draws oil through the valve stems past the valve stem seals. Could be worn guides and/or seals.
The amount of smoke shows how severe the problem is.
WintrSol
Florissant, MO
« Reply #6 on: September 17, 2016, 09:37:35 AM »
The only real trick to the job, is finding the spring compression tool that actually fits. Otherwise, it's just pick and place.
Tfrank59
'98 Tourer
Western Washington
« Reply #7 on: September 17, 2016, 02:24:57 PM »
well it might be something other than the motor that's smoking--that's the impression since it's during hard braking.  if it's oil smoke due to bad valve seals, you'd see some of that just idling, and you'd see the dipstick level drop over a period of time.  if it's brakes smoking, then you'd know it's rotors/pads or maybe some oil got on there.  I know if the fork seals leak enough it can get onto the rotors, in which case your brakes would be lousy--how were the brakes performing when you were doing that hard braking--normal, or less than?
-Tom
« Reply #8 on: September 17, 2016, 02:47:23 PM »
Re-read the post it say Engine Brakinge. ie using the gear box to slow the bike not the brakes.
« Reply #9 on: September 17, 2016, 03:39:28 PM »
and need to keep valves from dropping into the cylinder.
WintrSol
Florissant, MO
« Reply #10 on: September 17, 2016, 04:50:21 PM »
The only tool I could find to compress the springs required the head come off, anyway. There's very little room in there ...
Memor86
Tampico, Mexico
« Reply #11 on: September 17, 2016, 06:25:12 PM »
Couldn't it be related for a rich mixture on the carbs? I'm probably running too rich in the low jet
BonS
Blue Springs, MO
« Reply #12 on: September 17, 2016, 06:27:49 PM »
This the one that I used. It was important to get it seated on the spring close enough to the head to get enough compression but it worked every time and I never had a spring let go while it was compressed. I did have a friend lend an extra hand. I also used it on a GL1000 that has inner and outer springs and did it by myself without incident.
We never saw smoke while idling. It was only at start up or after deceleration. And in the beginning it only used an imperceptible amount of oil. That is, until we got into the mountains and used a lot of engine braking.
https://www.amazon.com/gp/product/B0002STSGC/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
CajunRider
Broussard, LA
« Reply #13 on: September 18, 2016, 02:13:26 PM »
What color smoke???
Light Blue (White) means oil (check guides as stated above).
Dark Grey (Black) means fuel (too rich on decel).  Reduce low speed jets by 1 size and see if it helps.
Sent from my Apple IIe
WintrSol
Florissant, MO
« Reply #14 on: September 18, 2016, 07:32:53 PM »
Thanks for that; it looks like another tool I need, so I just ordered one from WalMart.
