Steel cowboy
Spring Hill, Fl.
« on: September 18, 2016, 01:30:45 PM » |
Anybody try this yet? It claims it will work in 5 seconds and the applicator has a UV light to activate the resin. I'm thinking of keeping it in my trunk for emergency repairs.
2001 black interstate 2003 Jupiter Orange wing
dragonslayer
« Reply #1 on: September 18, 2016, 03:49:34 PM » |
I believe that's the same type glue used in dentist office.Where did you find it?
2k IS 98 Tour 2001 Stand
« Reply #2 on: September 18, 2016, 03:51:56 PM » |
Was actually just looking at it in a local flyer, on sale for $17.
I wonder how it would do in deep holes? If the UV light doesn't get to it, then how does it harden?
It might work on our broken plastic, only about 2 mm thick.
It was first available As Seen On TV. Now it's with Canadian Tire, so figure everyone has it.
« Last Edit: September 18, 2016, 04:05:09 PM by gordonv »
BonS
« Reply #3 on: September 18, 2016, 04:07:26 PM » |
The stuff works fine for relatively easy jobs. It does have to be built up in layers and each layer cured to build thickness. It also seems to have a decent shelf life sitting in my kitchen junk drawer! Doesn't everybody have a kitchen junk drawer?
« Reply #4 on: September 18, 2016, 04:11:06 PM » |
Bon, we have two....one for me and one for my wife. I don't understand why, but mine's always full.
Bone
« Reply #5 on: September 18, 2016, 04:16:24 PM » |
Organized junk drawers. I took the clear plastic insert from cookie packages. Actually 5 inserts side by side and try to organize my junk. Cuts search time way down.
« Reply #6 on: September 18, 2016, 04:23:43 PM » |
Mine worked okay to repair the tusk on a decorative elephant. I still think good ol' Gorilla Glue is a lot tougher, but GG requires a cure time and clamping.
The other drawback with this stuff -- the instructions mentioned you can't use it in sunlight because it "activates" (hardens) before you have a chance to apply it. It can even activate in the nozzle so you cant get it out of the bottle.
BTW, the stuff STINKS to high Heaven! Use it in a well ventilated area!
« Last Edit: September 18, 2016, 04:26:08 PM by Valkorado »
Steel cowboy
Spring Hill, Fl.
« Reply #7 on: September 18, 2016, 07:17:39 PM » |
Home Depot has it on sale for $ 9.78. I bought 2 one to try out on stuff the other to carry in my interstate trunk.
WintrSol
« Reply #8 on: September 18, 2016, 07:23:11 PM » |
It will probably age out pretty fast kept in the trunk on hot days. From the data sheet: "Recommended storage temperatures: 32 degrees Fahrenheit – 80 degrees Fahrenheit (0 degrees Celsius to 27 degrees Celsius)."
98 Honda Valkyrie GL1500CT Tourer Photo of my FIL Jack, in honor of his WWII service
hukmut
« Reply #9 on: September 19, 2016, 05:57:25 AM » |
Saw it demonstrated at a GW meet. Used it to glue a drive belt that was cut and glued. COULD NOT pull it apart!
Steel cowboy
Spring Hill, Fl.
« Reply #10 on: September 19, 2016, 07:56:42 AM » |
I have a spare fairing that has the blind nuts cassings cracked and a small chip ( which I have ) broken off the bottom. I am going to try it on it first. I also have a spare seat in leather that has a small rip in it. But I was thinking more like broken sunglasses and the likes or a repair on the road. I wonder if it can fix a screw in the tire. "No" I'm not going to try that on my tire for all those waiting to jump on that statement LOL
