February 12, 2026, 12:07:32 PM *
Author Topic: Oh Valk Gurus, a question about...'feelings'  (Read 1540 times)
Medina
Medina Ohio
« on: September 21, 2016, 03:34:46 AM »
lol..not long walks on the beach
When I turn, or lean left, I can 'almost' feel a slight...not a grind, not a vibration, closer to a slightest grind.
A hard left, no.
Lean right, right turn, no.
Noticed it messing around, feet on the pegs (thanks for the suggestions) going from rain gully to rain gully  on a one laner.
You'd really have to be paying attention, lean left to move to the left side of the lane, its there.
I feel it more in the handle bars, than anywhere.
Additional clue- sometimes...it feels like it "slips" in turns if I hit those tar snakes.
I've laid down a few bikes, so I do know exactly what its like when the front tire lets go and you greet the earth...so its NOT sliding, just feels like that- started about the same time this noise/feeling/vibration started.
I pulled my own front and took the wheel up for a new tire about...2000 miles ago. Have'nt done anything recently to suspect 'that' whatever if that makes sense.
Bearings?
bikes got 21,5 on it (put 5k on it since I got it this spring.) Love the thing, plan on riding till its not safe.
And I still wave to those dudes on a sunny day...the same ones I did NOT out see when it was cloudy, stuck in a long line of traffic cause I forgot THAT road was getting paved, threat of rain and chilly early in the mornings. Only got caught in one monsoon grade rain...dear god...haven't been that soaked in a long time.
Mich III on the front, Viper radials in the back, like glue in all conditions
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: September 21, 2016, 03:55:12 AM »
Sounds like a tire wear issue. Mine does the same but both sides. After the tires have been on several thousand miles is when I start noticing it.
Medina
Medina Ohio
« Reply #2 on: September 21, 2016, 04:14:15 AM »
Hmmm...that would put it at the notorious 7:00 positionish... And explain that funky slip in turns. All the tires i owned, never got a radial.
 Hmmm makes sense thanks.
Very odd feeling.
Wonder if its peculiar to mich 3's or all radials.
« Reply #3 on: September 21, 2016, 07:23:14 AM »
I've been running a Metz bias ply on the front along with a car tire in back. Got 17k on the last one, changed it due to age only, still with a lot of tread. I prefer the bias ply in front which also sticks like glue.
Medina
Medina Ohio
« Reply #4 on: September 21, 2016, 09:20:51 AM »
I thnk bias have higher load ratings too, no?
« Reply #5 on: September 21, 2016, 05:36:18 PM »
As a suggestion about 43  45 P S I in the rear and about 41  45 P S I in the front. Radials-after bias plys-take a bit of gittin used to. I'm on a Taxi tire in the back and a Shinko 777 White wall up front. They DO work well together-dry or REALLYREALLY wet!  2funny RIDE SAFE.
Firefighter
Harlingen, Texas
« Reply #6 on: September 21, 2016, 07:40:50 PM »
I would jack the bike and feel for rough front and rear bearings, neck and swing while you are there. Mine did that rough feeling if I was slow in a parking lot turning, but it was just the unused part of the tire on the pavement. I was worried and changed bearings but they were all good.
The slip on tarsnake, probably normal if I am understanding you, especially if your tire pressure is up in the 40's. Could check shock bushings or even your seat mounting, maybe handle bars and riser hardware tightness. Just ideas.
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
Medina
Medina Ohio
« Reply #7 on: September 24, 2016, 09:26:27 AM »
not on call, weekend for workin' on the thing I put more miles on this year than my van.  cooldude
8Track
Adelaide, South Australia
« Reply #8 on: September 27, 2016, 02:30:11 PM »
It sounds exactly like tread cupping on the rear tyre. I experienced this on my bike when I bought it from the previous owner. He ran low 30's PSI in both tyres.
When I put new tyres on the grinding went away. I always run 42 rear and 38 front.
Gideon
Indianapolis, IN.
« Reply #9 on: September 29, 2016, 05:16:14 PM »
I would put 42 psi in the front tire.
Since you have checked the wheel bearings, the only thing left to do is to turn up the volume on the radio.
