February 12, 2026, 12:07:31 PM *
Author Topic: Radio/CB Antenna's  (Read 1275 times)
Alberta Patriot
« on: September 23, 2016, 08:10:54 AM »
Is the antenna on the I/S for both Radio and CB if not where is the one for the radio.
Lyle Laun
Calgary, Ab
« Reply #1 on: September 23, 2016, 09:08:02 AM »
Wayne
Your's is for the radio only. There is another one if you have a cb
Lyle
Get out & Ride !!
98 Black "Rat Rod" Standard
99 Green/Silver Interstate
Alberta Patriot
« Reply #2 on: September 23, 2016, 09:41:10 AM »
Wayne
Lyle
Hey Lyle...yes mine has a CB...with the 2 sockets for driver/passenger...so where's the location of that  antenna? (not sure if you meant another location or another type of antenna)The reason being...I am planning to do the Super Valk Mod and wondered if it was necessary to have that whip antenna at the back if I don't use the CB while in S/V Mode. Actually I have never turned on the radio while riding so It's not like I will be real disappointed if the radio has no reception when the trunk is off. I installed a RAM X Mount on the bar next to the dogbone and will probably play my own tunes through my phone into the Aux plug. That mount was designed to attach to the bar with standard Zip Ties...worked great!
BTW...been meaning to return the exhaust tips...will get to that soon...if not home I will leave them on your step.
Went for a ride on the Highwood Pass last Friday...beautiful up there this time of year...got a little chilly at the summit...saw a group of riders from Colorado passing through up there.
« Last Edit: September 23, 2016, 10:14:42 AM by 7th_son » Logged
« Reply #3 on: September 24, 2016, 09:07:33 AM »
The stock IS comes with a radio/intercom system, NO CB.
CB is an add on (OEM or aftermarket). The ant is identifiable if there is that black block on the antenna.
You most likely do not have a CB, only the plugs to use it and the intercom.
The CB ant gets mounted on the left side of the trunk opposite the radio ant.
« Last Edit: September 24, 2016, 09:36:32 AM by gordonv » Logged
