February 12, 2026, 12:07:35 PM *
Author Topic: Leaking oil around shifter seal  (Read 1273 times)
« on: September 23, 2016, 02:59:46 PM »
After the meet in the middle ride when I got home I noticed oil dripping near the front of the engine. Took a look and suspected shifter seal after all this is a 20 yr old Honda not a 20 yr old HD 2funny
Well today I decide to replace it. So after getting the shifte off the splines and the shifter rod from enginge off ( bugger ) I discovered the seal wasnt bad but bad slipped
Out of the hole. I compared it to the new one and zero difference. Could have probably pushed that one back in and been fine but ponied up the $2.58 and pjt the new one in crazy2 oh and when I ordered that one I got two spares cooldude
BTW the one replaced was the original.  $2.58 for a twenty yr old part cant beat it angel
« Last Edit: September 23, 2016, 03:01:39 PM by Bighead » Logged
« Reply #1 on: September 24, 2016, 06:23:51 AM »
 cooldude Bullet Proof!
My rides:
« Reply #2 on: September 24, 2016, 06:27:36 AM »
Mine looked pooshed out too, when I replaced it. Mine made a mess of
the bottom of my motor, it is hard to clean all that gunk off!
Medina
Medina Ohio
« Reply #3 on: September 24, 2016, 09:25:11 AM »
oven cleaner
long soft wire brush
water
« Reply #4 on: September 24, 2016, 09:40:39 AM »
oven cleaner
water
How does it behave on aluminum? I need to clean my motor, figured I would try the Simple Green, but I never found that stuff good enough to degrease my car engine.
Harryc
Sebastian, Fl
« Reply #5 on: September 24, 2016, 12:18:37 PM »
Try aluminum wheel cleaner.
« Reply #6 on: September 24, 2016, 12:23:10 PM »
Our motors are painted, so I don't guess cleaners really
know what material is under the paint... ?
« Reply #7 on: September 25, 2016, 06:27:12 PM »
OK, don't believe me.  Mean green from the dollar store or Lowes
This is when the bike wasn't much over 100,000 miles and after the shifter seal mess
« Last Edit: September 25, 2016, 06:29:50 PM by Chrisj CMA » Logged
« Reply #8 on: September 25, 2016, 09:25:04 PM »
Chris, I know, that's why I'll try it again. Maybe it's the tooth brush and laying on your dolly that will make this work.  cooldude
« Reply #9 on: September 26, 2016, 04:38:04 AM »
I'd be happy to help if you drop by, but you can't lay on my dolly!
« Last Edit: September 26, 2016, 12:53:34 PM by Chrisj CMA » Logged
Woton
Central North Carolina
« Reply #10 on: September 26, 2016, 12:40:47 PM »
Yep, had to replace mine upon returning home from Inzane at 63K.  Easy Peasy Smiley
Always a shock to see ANY oil on the mat under the Valk. Shocked
Just ONE reason why we ride 'em...  cooldude
« Last Edit: September 26, 2016, 12:43:08 PM by Woton » Logged
"Ride Smart - Ride Safe"
