April 30, 2026, 07:00:42 AM *
Author Topic: Just two issues to settle...  (Read 3571 times)
AdrianR
Far North Chicago Burbs'
« on: September 25, 2016, 09:27:18 AM »
Okay, I have had this bike now for roughly 15 months, and with nearly 7800mi. on the odometer, the engine is really coming to life.  Man, run the tank down to like a 1/4 tank, ethanol free gas...10w/30 LUCAS OIL full synthetic(this is the best oil guys for this bike man..for what I have tried) and this bike is a fricken rocket...especially once you really learn how to work it's power band and transmission...  AMAZING drive train....and handling characteristics...  However, two issues I have to settle to make this bike complete for me.
1. finding the correct height windshield. This bike is not that aerodynamic... wind blast and turbulence over 80mph just rattles your eyeballs...and glasses, head gear, etc.  Have any you solved this problem?  What did you find for your height as the correct sized windshield to eliminate the buffeting?
2. The grips.  Sometimes my throttle hand just gets prematurely numb.  How did you solve this issue?
Michvalk
Remus, Mi
« Reply #1 on: September 25, 2016, 10:43:19 AM »
My hand gets numb pretty fast. I slid on of the cheepie palm rests on the throttle side, and cured the problem. I have no answer for the buffeting cooldude
AdrianR
« Reply #2 on: September 25, 2016, 10:51:36 AM »
What is a 'palm rest'?
six2go #152
Ft. Wayne, IN
« Reply #3 on: September 25, 2016, 11:44:37 AM »
Adrian, You might try these to fix the grip problem. I used them on the V-Strom and F6B until I went with ISO's on the B. They're cheap, easy to install and quite comfortable. Here ya go.....http://www.shop.shinhopples.com/product.sc?productId=1067&categoryId=103
For a palm rest I like the KuryAkyn universal throttle boss. Works on most grips and will also work with the above mentioned foam covers with some stretching but not at all hard to do.
Good luck.
AdrianR
« Reply #4 on: September 25, 2016, 11:58:26 AM »
Good luck.
Cool...thanks...I will order those..geezz...for like $11.00 shipped how can you go wrong!
sleepngbear
RI
« Reply #5 on: September 25, 2016, 11:59:26 AM »
Lots of options for these. Here are a few:
Kury Throttle Rocker
Kury Throttle Boss (attaches to the end of Kury ISO grips)
Cramp Buster (works on any grip like the Throttle Rocker):
TallRider
Cape Coral, Fla
« Reply #6 on: September 25, 2016, 05:36:21 PM »
I am 6'4" and installed the OEM Honda tall windshield  added a 1 1/2" link to the bottom bracket pushed the bottom out solved the puffeting  problem for me.
1951 HD FLH Chopped
1978 Honda Goldwing
2005 VTX 1800
2014 Honda Valkyrie
AdrianR
« Reply #7 on: September 25, 2016, 05:53:42 PM »
Where does the shield end with respect to your line of sight?
Moofner
Colorado Springs, CO
« Reply #8 on: September 25, 2016, 06:19:55 PM »
I know it shall sound oddballish, but I'm very happy with my full face helmet and sports windshield w/ wind deflector combo.
The air is pushed upwards and hits the top of my helmet, right at the intake port to keep my head cool. I also think the screen looks pretty snazzy on the bike.
It would be a nightmare if you are riding open face or skull cap.
2003 Valkyrie "Ricky's Bike"
2014 Valkyrie "The Gypsy Bride"
TallRider
Cape Coral, Fla
« Reply #9 on: September 25, 2016, 06:30:39 PM »
Top of shield eye level for me.
1951 HD FLH Chopped
1978 Honda Goldwing
2005 VTX 1800
2014 Honda Valkyrie
Kidd
Sedona
« Reply #10 on: September 25, 2016, 07:29:08 PM »
In a earlier thread , you were complaining about the ridged rear end .
Di you fix that problem ?
Verismo
« Reply #11 on: September 25, 2016, 08:40:39 PM »
I haven't gotten the grip/handlebar issues sorted, yet, although I improved the grips from stock with Kuryakyn ISO's and a CrampBuster.  I think the angle of the grips only bothers me because the bars are just a bit too far forward and you can't adjust the damn things except by rotation.
However, I have totally fixed the windshield problem, and I'll post that as a new topic in Tech.  Madstad worked with me and they did a fantastic job and deserve their own post.  If you're looking for a quick and easy fix, though, installing those small tabs at the base of the stock windshield does a pretty decent job.
AdrianR
« Reply #12 on: September 26, 2016, 03:46:47 AM »
Do you look over the top of the shield, or is the shield slightly above you line of sight? Or does the top of the shield run directly through the middle of your line of sight?
texrider
« Reply #13 on: September 26, 2016, 06:11:21 AM »
Installing the Oxford heated grips gave slightly increased diameter that helped with fatigue.
Using the boulevard shield lets clean airstream flow at shoulders and helmet to avoid buffeting, but at the expense of less protection.
More air works fine for me.
2014 GL1800C Blue
JimmyG
« Reply #14 on: September 26, 2016, 07:24:56 AM »
Hey AdrianR, I changed oil and went with the Lucas oil.  I am very impressed with the results. I've used a couple other brands and so far, I agree with you, best I have used. Smmmmoooooooothe is all I can say. cooldude
OdentonValkyrie
« Reply #15 on: September 26, 2016, 12:12:40 PM »
I've been very impressed with this. Looks good and is cheap. Protects very well at high speeds.
http://www.revzilla.com/motorcycle/national-cycle-deflector-screen-dx-windshield?utm_source=product&kwd=&gclid=CNSArvLgrc8CFcImhgod-kEFeQ
AdrianR
« Reply #16 on: September 26, 2016, 01:20:03 PM »
So you can notice the diff too eh?...That's great man. cooldude  I know there are some people that think oil really makes no difference in performance...  well their wrong as IT DOES... Did you also notice how it revs faster?  So far I have tried Valvoline's 10/40w petroleum based *motorcycle* oil, Honda's 10/30w full synthetic oil, Castrol's racing 4T 10/40w full synthetic oil, and Amsoil's 10/30w full synthetic oil.  The Lucas Oil really outperforms all them quite noticeably...  The bike is faster with the 30w oil btw as well....
« Reply #17 on: September 26, 2016, 03:53:52 PM »
Adrian you know how my bike is set up and I have not had buffeting except on very rare occasions with the Honda OEM windshield. My eyes just looks over the top if I straighten up in the seat. We have some pretty good cross winds here and I have not had that kind of problem.
As for the numbing issue I still deal with it on occasion but if I wear gloves I usually dont have a problem. If you get some gloves like weight lifter gloves with padding in them you should be ok.
« Last Edit: September 26, 2016, 03:57:36 PM by Robert » Logged
dinosnake
« Reply #18 on: September 29, 2016, 11:00:41 AM »
I'm at 13 months and 14,000 miles and there are definitely easy solutions to the problems you specify.
For the wind issue, look to
https://bikescreen.com/collections/popular-items/products/honda-goldwing-valkyrie-f6c-2014-2016
With 9 different shield sizes to choose from, you can find your prefect fit.  I have the 8" and have been considering adding a 12" for cooler weather.
For the hand cramps, you get either a CrampBuster or a ThrottleRocker, I won't leave home without one (seriously!  When I went in vacation and rented a bike I brought my TR along!)
Next, you need a throttle lock.  Since I'm running heated grips I went to GoCriuse
http://www.2wheelride.com/throttle_pro.html
A bit fussy to use in my circumstance due to those heated grips, but it does work.  Inexpensive.  More deluxe systems out there if it pleases you.
Karen
Boston MA
« Reply #19 on: September 29, 2016, 05:30:29 PM »
You could consider some gel gloves; I had a similar problem when I was doing a lot of bicycle riding, and have not had an issue since getting the gel in the palm gloves.
AdrianR
« Reply #20 on: October 07, 2016, 03:21:18 PM »
Good luck.
Hey, these things work! Just got them last week and installed them.  Hand numbing issues GONE.  And, they were only like $12.00 shipped to me.
six2go #152
Ft. Wayne, IN
« Reply #21 on: October 07, 2016, 03:58:18 PM »
Good luck.
Damn, someone finally tried one of my tips, and it worked! cooldude
barney fife
Meadows Place, Texas
« Reply #22 on: April 18, 2017, 06:13:08 PM »
I have Honda's short windshield.  Very happy with it, but I'm only 5'6".  All I want is something to knock the blast off my chest.
21 Tenere 700
18 CB1000R Neo Cafe
16 Super Tenere
16 R3 Endurance Race Bike
14 Valkyrie
