January 29, 2026, 07:51:04 PM *
Author Topic: Why not different sized jets for cobra pipes?  (Read 1914 times)
Cinco
« on: October 01, 2009, 07:21:16 AM »
Did some searching, and found that with the cobra 6 to 6 pipes, the only problem with jetting is that the pipes are different lengths, and jetting does not really match what is needed.  Why not vary the jetting, to match the pipes?  I have jetted numerous inline 4 engines, and have varied the jets based on inside/outside or exhaust routings.  Unfortunatly for me I don't have a big assortment of jets to try out, unless they might be the same as the ones for my kaws, but most of the ones I have would probably be much larger anyway.  Maybe I'll start gathering an assortment now.....  Has anyone tried staggering jets?
« Reply #1 on: October 01, 2009, 07:56:25 AM »
unless u let in more air, no need for more fuel.
http://www.valkyrieforum.com/forum/tech_archive.cgi?read=969520
This was posted by J. Orr, 3/27/1998, on the GWRRA BBS, valkyrie section.
The following mods were done by Marc the owner of Factory Pro of a valkyrie that had cobra 6x6 pipes.
K&N filter (w/o prefilter)
Air box mod (remove plastic welded baffle)
38 pilot jet
3.5 turns idle mixture screw
front needles set on #3
mid and rear needles set on #2
115 main jets all carbs
this picked up 5 hp over the base run with the cobras.
this HP is still down from the stock pipes or almost the same.
Slammer
Lafayette,La.
« Reply #2 on: October 01, 2009, 01:15:33 PM »
the last 7 or 8 years. I always put the stock needles and springs back in  first thing. Always set the pilots at 2.25 turns out. They run good and get decent mileage.
