February 12, 2026, 12:07:32 PM
99 IS pilot screw turns
Topic: 99 IS pilot screw turns (Read 1168 times)
Memor86
Tampico, Mexico
September 29, 2016, 12:58:15 PM »
how many turns should the pilot screw be set on a 99 IS bike?
nerider2
Omaha, NE
Re: 99 IS pilot screw turns
September 29, 2016, 01:28:42 PM »
NITIAL OPENING:
'97 GL1500C/CT:
Except California type : 1-3/4 turns out
California type : 2 turns out
GL1500CF, After '97 GL15OOC/CT:
Except California type : 2-1/4 turns out
California type : 2-3/8 turns out
1. Turn the pilot screw clockwise until it seats lightly, then
back it out to the specification given. This is an initial setting
prior to the final pilot screw adjustment.
2. Warm up the engine to operating temperature. Stop and
go driving for 10 minutes is sufficient.
3. Stop the engine and connect a tachometer according to
the tachometer manufacturer's instructions ( A Digi Sync will do).
4. Start the engine and adjust the idle speed with the throttle
stop screw. IDLE SPEED: 900 +/- 100 rpm.
5. Turn each pilot screw 1/2 turn out from the initial setting.
6. If the engine speed increases by 50 rpm or more, turn each
pilot screw out by successive in 1/2 turn increments until
engine speed does not increase.
7. Adjust the idle speed with the throttle stop screw.
8. Turn the No.1 carburetor #1 pilot screw in until the engine
speed drops by 50 rpm.
9. Turn the #1 carburetor pilot screw out to the final opening
from the position obtained in step 8 by 1 complete turn out.
FINAL OPENING: 1 turn out
10. Adjust the idle speed with the throttle stop screw.
11. Perform steps 8, 9 and 10 for the No. 2, 3, 4, 5 and 6
carburetor pilot screws.
2014 Daytona Blue Ultra Limited
2000 Stealth Interstate
1999 Excelsior-Henderson
Omaha, NE
VRCC #23874
Iron Butt Association #32532
Memor86
Tampico, Mexico
September 29, 2016, 01:55:54 PM »
how is one supposed to turn the pilot screw with the bike runing?, i was thinking i had to remove the elbows to reach!
September 29, 2016, 03:15:03 PM »
Special tool from honda that's big bucks.
I bought this:
https://www.powersportsplace.com/parts/ptm-pp2821?seid=pspse1&cm_mmc=pla-google-_-shopping-_-pspse1-_-pit-posse-motorsports&gclid=CjwKEAjw8da8BRDssvyH8uPEgnoSJABJmwYoBYnOcRgRzFUILzou8OX9yCvl7eO8E6ThzZV7F4RtYBoCu-Pw_wcB
Others have made their own small tool, but that requires heat proof hands.
October 02, 2016, 04:53:57 AM »
I remove the screws/needles and cut a slot in them. Add a dab of never-seize to the threads. I also just set them at 2.25 turns and go.
