March 15, 2026, 08:28:10 AM
1800 Tech Board
Need 12volt switched at headlight.
Topic: Need 12volt switched at headlight. (Read 2378 times)
Bobvalk
Sanford, Florida
September 30, 2016, 12:17:56 PM »
I'm hooking up cell phone and would like to get 12v from up front near headlight. I'll then transform it to 5v USB. Has anyone opened up headlight wiring?
Re: Need 12volt switched at headlight.
September 30, 2016, 12:33:32 PM »
root around on rattlebars.com for chet's valkyrie schematics...
Firefight100
USA
September 30, 2016, 04:50:35 PM »
Coming out of the keyed ignition switch are 3 wires. red is 12 v positive all the time. Black goes to the fan circuit and green is 12 positive when the switch is on. Just remove the gas cap cover to access. There is a quick disconnect under the cover. No need to remove the switch.
https://SecreLocal.com
Emmie Murray Aurora
Melissa
Vanessa
Haley
Bobvalk
Sanford, Florida
September 30, 2016, 06:09:25 PM »
Thanks much, I'll give that a go tomorrow!
hungryeye
Scottsdale AZ & Climax NC, formally freehold, nj
October 01, 2016, 05:46:57 AM »
There is an OEM kit for a 12v plug in under the seat, I don't know what they were thinking, you would have to pull the side cover to plug in your devise for charging, makes no sense. I matched up by eye the plug under the seat at cycleterminal.com and ran the wire under tank to handlebar. You can just cut the OEM plug off and splice but I hate to hack a wire harness on a brand new bike.
Cycle Terminal has just about any electrical plug for any motorcycle. I don't have the part number but their pictures are easy to match what you need, usually its the male end you need. You get the plastic blank and crimp on connector, stick the wire through the blank, crimp on metal connector and pull to lock into blank. Might cost 10 bucks to do this.
2014 F6c Red ish
1983 GL650 cream puff
2010 Spyder RS
we DRIVE our cars, we RIDE our motorcycles!
rogueleader_92
SLC, Utah
October 01, 2016, 10:10:30 AM »
You wouldn't have to pull the cover every time, just plug in a charger then run the wire to your trunk/bags.
There I lay, broken and bloody, my life slipping away when a beautiful winged woman in glorious golden armor appeared.
"Come with me" she said.
"To where?" I asked.
"To Valhalla"
