February 12, 2026, 02:24:19 PM *
Author Topic: Alright, who is stealing my front brake fluid. Stop It!  (Read 1667 times)
« on: October 02, 2016, 12:56:24 PM »
Filled up the reservoir 2 weeks ago to the line on the sight glass.
Now after about 500 miles the fluid is down to the bottom of the sight glass.
Yes I had the reservoir flat and level when I filled it up.
bill-jr
VRCC # 35094
murfreesboro
« Reply #1 on: October 02, 2016, 01:52:38 PM »
Close your bleeder paul .... Grin Grin Grin
99' Black tourer
« Reply #2 on: October 02, 2016, 08:41:55 PM »
Or put new pads on .
« Reply #3 on: October 03, 2016, 02:26:01 AM »
Pads half dead
« Reply #4 on: October 03, 2016, 07:40:49 AM »
If your pads were spread apart (i.e. caliper pistons pushed in) when you added the fluid, using the brake to bring the pads to their normal position next to the rotor will require some of the fluid to move down to the pistons, thus lowering the level.  Pad wear will cause the level  to drop over time, as well.
« Reply #5 on: October 03, 2016, 08:09:05 AM »
Didn't touch pads.
« Reply #6 on: October 03, 2016, 11:03:51 AM »
Put a splash more in and will see what happens when next I ride.
Took the caps off the bleeders and there's no moisture I can see.
Daniel Meyer
The State of confusion.
« Reply #7 on: October 03, 2016, 03:13:39 PM »
You should never have to add once bled/etc...the pads wear, the fluid goes down a bit (but not below line), ya add new pads, fluid goes back up.
You have a leak. Fix it. Sudden failure of a caliper seal or master cylinder is trouble you don't want...
CUAgain,
Daniel Meyer
« Reply #8 on: October 03, 2016, 05:17:03 PM »
Firefighter
Harlingen, Texas
« Reply #9 on: October 03, 2016, 06:46:14 PM »
If you are leaking fluid it should be all over everything, it doesn't go away without cleaning.
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
« Reply #10 on: October 03, 2016, 06:48:50 PM »
That's what's puzzling  ???
« Reply #11 on: October 04, 2016, 07:25:57 AM »
No discernible leaks form bleeder, hoses or junctions.
Next step remove calipers and check for a leak?
« Reply #12 on: October 04, 2016, 08:25:55 AM »
I've never had a leaky caliper that I know of, but if one of those piston
seals was leaking just a little, maybe your level would go down and
all the "action" happening at the caliper pistons might make it harder
to see a leak than if it was happening at one of the junctions.
I've had a junction leak once or twice, even if you can't really see it,
that brake fluid will find its way out if there is one... I could feel
the fluid, more than see it, at the leaky junction.
« Reply #13 on: October 04, 2016, 08:31:59 AM »
Ill do a feel and tissue test.
« Reply #14 on: October 05, 2016, 05:44:45 AM »
Touch test done all the way from the reservoir to the calipers.
Nuttin.
Valkpilot
What does the data say?
Corinth, Texas
« Reply #15 on: October 05, 2016, 07:02:40 AM »
Nuttin.
Is there any difference in lever and braking "firmness" before and after the apparent loss?  Is it possible there was air in the line that worked its way out to the master cylinder?
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #16 on: October 05, 2016, 08:56:15 AM »
Nuttin.
Don't think so.
« Reply #17 on: October 05, 2016, 11:08:53 AM »
Well then, if there is no indication of a leak I would think you must have been mistaken in you observation and assumption.
« Reply #18 on: October 05, 2016, 11:36:45 AM »
Didn't touch pads.
I always have to spread the pads a little to ease in reinstall.
« Reply #19 on: October 09, 2016, 06:36:14 PM »
No more theft of brake fluid. After 200 miles today and 200 last weekend the level in the window is as it should be.  cooldude
