January 29, 2026, 07:51:06 PM *
Author Topic: Turn Signal Lense Question ??  (Read 1843 times)
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« on: October 01, 2009, 12:30:31 PM »
1997 Tourer with Cobra light bar. The rear turn lenses are the 2 screw attachment and the front are the single screw attachment. Shouldn't they be the same. Have these been swapped put or was that part of the adding the Cobra light bar. Going to clear lenses and want to get the correct ones. TIA, Dave
vanagon40
Greenwood, IN
« Reply #1 on: October 01, 2009, 12:51:22 PM »
From the factory, both front and rear lenses required two screws
http://www.hdlparts.com/fiche_section_popup.asp?fveh=3476&section=148762&year=1997&make=HONDA&category=MOTORCYCLES&tiercode=&dc=2291&name=TURN+SIGNAL+%281%29
Williamsburg, KY
« Reply #2 on: October 01, 2009, 12:55:36 PM »
That's what I thought. Was wondering if when installing the cobra bar you reuse your turnsignals ( I assume this as well) which leads me to believe that the PO must have changed these out for some reason. Thanks for the response.
The front ones on mine have a single screw that goes thru the front not underneeth as some show on the parts list at HDL.
« Last Edit: October 01, 2009, 01:00:56 PM by Misunderstood » Logged
DFragn
« Reply #3 on: October 01, 2009, 01:16:08 PM »
Quote from: Misunderstood
If you remove the lens you may find the turn bucket has 2 threaded receivers.
If the front turn buckets match the rear in size, dimension & stem with rubber isolater odds are the P.O. only changed out the front lenses with an inappropriate lens for whatever reason.
« Last Edit: October 02, 2009, 04:03:00 AM by DFragn » Logged
« Reply #4 on: October 01, 2009, 10:36:47 PM »
The single screw housings are from a newer Valk (or another newer Honda). The PO must have gotten new ones for some reason.
Udo
Germany, Krefeld
« Reply #5 on: October 02, 2009, 02:28:50 AM »
Afaik, Cobra had 2 light bars, one for the older Valk´s, one for the newer with single screw. Perhaps, the PO got the bar for the newer Valk´s, for some reason, and needed to use the newer blinker version, to fit the light bar....
