February 12, 2026, 02:24:28 PM *
Author Topic: Cobra 6x6 exhaust  (Read 1028 times)
« on: October 07, 2016, 08:14:41 PM »
Reading about the Cobra 6x6 exhaust. I suspect from talking with the PO that he just put the new exhaust on the bike. I hadn't asked yet if he re-jetted the carbs. I don't know if I'll keep them on the bike, but so far I like them. It will all depend how the noise is on a long trip.
So back to the Cobra's. Seems I should be looking at the spark plugs for how rich the carbs are running?
If I switch back to the OEM exhaust, same thing, inspect the plugs.
Does this sound about like what I should be doing?
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #1 on: October 08, 2016, 08:01:39 PM »
if the po hasn't rejetted, then you shouldn't have to worry about the stock pipes. i don't like too msny of the aftermarket needles which have adjustible clips .... i prefer stock needles.  with the cobras , i have 38 slow jets, and 105 main jets, and have the fuel air screws backed out 1 1/2 turns from stop.
matutum
« Reply #2 on: October 09, 2016, 08:55:21 AM »
If I switch back to the OEM exhaust, same thing, inspect the plugs.    As for noise I wear ear plugs always-
« Reply #3 on: October 09, 2016, 10:29:01 AM »
Is there a gasket that needs replacing, if I remove the cover to inspect the needle, to see if it is stock or not?
Roidfingers
Tuscaloosa, Alabama
« Reply #4 on: October 09, 2016, 12:48:38 PM »
There is a gasket for the bowl, but I didn't change mine when I rejetted. No problems.
