January 30, 2026, 02:06:00 AM *
Pages: 1 [2]   Go Down
Author Topic: Turn signal "on" reminder...  (Read 12291 times)
blackcat
Nicholas Vore VRCC # 30301
Mounds, Arkansas
« Reply #40 on: November 26, 2009, 01:37:19 PM »
ken that is a very good idea, but as joop said it seems that it would blind you at night
i have the 2-B-Seen lights and in the daytime i can barely see them, but they are extremely noticable to other drivers even on very sunny days, much more than stock turn signal lights so it adds to the danger, and i have forgot to cancel it several time
i have ridden one with a blinker buddy but sitting at stop lights it gets annoying then i just turn it off, and then  forget before to turn it back on before turning
______________________
03 Standard -Fast Black
00 Interstate - Red/Black
97 Tourstate - Yellow/Ivory
2010 Goldwing - Pearl Yellow
joop angelier
Greetings from the Netherlands
Netherlands
« Reply #41 on: November 26, 2009, 10:44:45 PM »
Hello Blackcat
You need my divice: http://members.home.nl/joop.angelier/download/Richting%20aanwijzer%20indicator/USA/
No alarm if it's not necessary.
Greetings joop
X Ring
VRCC #27389, VRCCDS #204
« Reply #42 on: November 27, 2009, 01:51:20 AM »
Joop, what's the price in U.S. Dollars?
joop angelier
Netherlands
« Reply #43 on: November 27, 2009, 09:13:28 AM »
The price is 50 euro.
That's about 75 dollar.
The shipping cost is about 12 dollar.
But tell me if it's to expensive.
I forgot to mention that it has an output to connect a blikerbuddy or something like that.
So it will only vibrate if you drive faster than 15m/h and you forgot your blinker for more than 30 seconds.
Joop... laugh
Ken Tarver
North Mississippi
« Reply #44 on: November 30, 2009, 09:23:07 PM »
it's not blinding at night for me....maybe your eyes would be more sensitive than mine, if it is for you, just take a strip of electrical tape and put over it at night....
inside the headlight bucket, i found two wires with female bullet connectors on them that happened to also be the left and right turn signal.....thats where i wired it in.
Ken
skromfols
You only go around once
Valley Springs, Calif
« Reply #45 on: December 01, 2009, 06:32:49 AM »
Ken
Thanks Ken.  That should give me a good start.
Stan
Stan
Ken Tarver
North Mississippi
« Reply #46 on: December 01, 2009, 07:03:56 AM »
oh by the way......the picture wasn't taken from a sitting position on the seat, so the angle you see the light from the seat isn't directly looking into the end of the LED where it is the brightest
Wildman
« Reply #47 on: December 01, 2009, 01:07:39 PM »
The most helpful advice I've heard, was on this board, "to cancel the turn signal just before the end of the turn", so that it becomes part of the turn. Think about where the best point for cancelling the signal is, and eventually it will become more automatic.
I have a signal buddy. It works at low speed, but believe it or not, at higher speeds it fades into the vibration from the motor. Yes it is a Valk
My signal buddy is just stuffed between the seat shell and the foam on an Ultimate seat. I think that Ulmiate will install it for you when you buy the seat if you want. There's probably a better place to install (closer to the surface) than on my bike.
I didn't want anything making noise like a busser.
I like the signal buddy it does wake you up when you have forgotten "at low speed"
I still forget to cancel sometimes, but is rare.
rwoulf
« Reply #48 on: December 02, 2009, 09:15:34 AM »
I forget to turn them off also especially during the day, bought the Kissan did not like set up, i bought Blinker Buddy good people to work with. i have not forgotten to turn off since. You can buy stuff at radio shack to make buzzer and reminders but I'm electrically challenged, Smiley B B was easy.
TearlessTom
Spanish Fort, AL.
« Reply #49 on: December 02, 2009, 02:10:20 PM »
If you don't want the noise over on the ST boards they came up with a devise which is a simple single LED light. In the Valkyries case it would be mounted on the triple tree in such a way it reflexs onto the windscreen at about eye level and flashes with the turn signal.  On the interstate model it can be mounted on top of the dash area .
Here is a link for more details.
http://www.st-owners.com/forums/showthread.php?t=32074&highlight=turn+signal+reminder
Tom
sheets
Jct Rte 299 & 96, Calif.
« Reply #50 on: December 02, 2009, 06:26:53 PM »
The turn signal cancel button will be the first thing to wear out on my bike.  I've trained myself years ago (like tying your shoes) to make certain its off.  Just going down the road my ritual is to push on the cancel button, and the choke lever, every so often just to make sure they're off/closed.  Call me obsessive compulsive.  That's okay.  That's just the way it is with me.  A sure fire way to get yourself hurt is to leave the turn signal on.  Yrmv,
rmrc51
Palmyra, Virginia
« Reply #51 on: December 03, 2009, 03:27:05 AM »
When I ordered my Ultimate seats, I also had them install one of their options called the 'Blinker Buddy'. When you have your directional on, the seat vibrates. There's no way you can forget that your signal is still on. lol  Grin
VRCC # 30041
Pages: 1 [2]   Go Up
