March 29, 2026, 06:25:41 AM *
Pages: [1] 2 3   Go Down
Author Topic: Laufenn G FIT tire, My first DarkSide, Ride Update  (Read 14352 times)
« on: October 08, 2016, 01:41:16 PM »
 205/65-16 H rated.  made by Hankook
http://www.laufenn.com/us/front/us_front/gfit.do#
Really like the tread pattern, equal roundness both sides. measured about 4" between both sides of tread where it starts to round off. 6" wide at the round drop off. forgot to add that the Austone is 5.5" wide for comparison.
$75 out the door at PepBoys.
it's a 4 ply tread tire but only 1 ply sidewall. max load 1521 lbs. max pressure 51 lbs. This is more than the E3 on now.
old E3 both are mounted on rims.
This is an inflated tire. 3 inches from tread to tread and then it rounds off to both sides.
« Last Edit: May 08, 2019, 10:15:18 AM by 98valk, (aka CA) » Logged
« Reply #1 on: October 08, 2016, 02:05:40 PM »
I like a softer (IE normal, all season radial) sidewall (that flexes and keeps the tread on the road until hard leans), but that tire is asymmetrical (maybe that doesn't matter).
« Reply #2 on: October 08, 2016, 03:23:44 PM »
First D/S tire I used-General Altimax-took me bout 6 or 7 miles to git used to it. All I can tell ya it is a bit Different-NOT bad different-Just different. BUT I will say this-much like riding itself-there is NO in between. Good fortune and RIDE SAFE.
DarkSideR
Pueblo, Colorado
« Reply #3 on: October 10, 2016, 05:51:23 AM »
I ride the Hankook Optimo H426 which looks to be very, very similar to the Laufenn. I have over 9k on the tire. All of those miles have been great. The tire handles excellent, and the softer sidewall may lessen the bump steer effect. I cannot recollect any bump steer since I have had the Hankook.
I suspect it is a re-branded Optimo with a slightly different tread pattern. If so that is a deal.
2001 Valkyrie Super Tourer
VRCC#34410
VRCCDS#0263
« Reply #4 on: October 10, 2016, 07:13:46 AM »
your tire was on my list. Thanks for the report. Never saw one in person, but from pics it looks like, as many tires today do, to have different left and right roundness profiles as some which I saw in person do. This Laufenn has equal roundness profiles both sides of tire which I like and will give same handling left and right.
I should have it on by the weekend on my very low mileage 5-8k (still has the OEM dunlop w/4/32" tread left) trike take off complete '03 wheel I picked up last week.
Present E3 w/beads lasted 22k miles.
« Reply #5 on: February 20, 2017, 05:10:16 PM »
Bump, added pictures.
« Reply #6 on: February 20, 2017, 05:22:17 PM »
That looks nicely rounded over.
Have you put this on your bike?
« Reply #7 on: February 20, 2017, 06:10:42 PM »
mounted on rim, installing sometime this wk.
N0tac0p
« Reply #8 on: February 21, 2017, 04:08:33 AM »
question.  why go with a 65 aspect ratio vs a 55.  I would think with the wider 205 that the 55 would give the same approx. overall dia, whereas the 65 would be effectively larger, giving more error on the speedo and apt to rub inside with 2 up.
just trying to educate myself
« Reply #9 on: February 21, 2017, 04:17:34 AM »
does not effect speedo/odo which are taken off the front wheel.
205/65 not known to be a problem rubbing. 205/65 will lower engine rpms @ 60 mph about 200rpms.  there are many posts about tire sizes and which dark side work well and which do not.
« Reply #10 on: February 21, 2017, 04:20:04 AM »
Hopefully the weather continues to improve and you can get us a report.
N0tac0p
« Reply #11 on: February 21, 2017, 04:55:31 AM »
something I had not thought about, but it came up in one of these strings,  and that is getting a shop to give you an inspection sticker
« Reply #12 on: February 21, 2017, 10:12:12 AM »
  I've never had a problem getting an inspection sticker with my ATT.  One guy said something like "That's a wide tire, must ride like crap" to which I told him, it did not.
« Reply #13 on: March 09, 2017, 10:33:20 AM »
Ride Report!
All I can say is awesome! This is my first CT and basically there was no difference from the E3 I took off. And the RPMs are down about 200.
I thought I was going to have to employ a little more force to transition or go around a corner or off ramp. None was needed, bike reacted just like it did before with the E3
I even rode a hwy with present road construction, a lot of uneven road surfaces, there was no difference than the E3.
I'm a Dark Sider for life now.
« Last Edit: April 02, 2017, 04:52:08 PM by 98valk (aka CA) » Logged
« Reply #14 on: March 09, 2017, 11:15:18 AM »
installed with new light weight rotor. only 3lbs vs '98 at 4lbs 4 oz, vs '03 at 6 lbs.
reducing unsprung weight is always a great benefit.
« Reply #15 on: March 09, 2017, 12:12:52 PM »
Where did you get the rotor from?
DarkSideR
Pueblo, Colorado
« Reply #16 on: March 09, 2017, 12:25:03 PM »
Ride Report!
All I can say is awesome! This is my first CT and basically there was no difference from the E3 I took off. And the RPMs are down about 300.
I thought I was going to have to employ a little more force to transition or go around a corner or off ramp. None was needed, bike reacted just let it did before with the E3
VRCC#34410
VRCCDS#0263
« Reply #17 on: March 09, 2017, 12:27:19 PM »
ebay, it is sold by bikemaster, this is who makes it for them, http://ngbrakedisc.com/catalogoonline.htm
« Reply #18 on: March 09, 2017, 12:40:32 PM »
Doing a search for bikemaster gives over 95,000 results.
Searching in that gives no hits for disc or Valkyrie
« Reply #19 on: March 09, 2017, 03:19:15 PM »
I forgot, it is listed for the Goldwing GL1500, same rear rotor as valkyrie.
 Bought it last yr for $55 shipped.
BM #962069
http://bikemaster.com/replacement-parts/brake-system/rotors/brake-rotor-4551.html
 REAR 316x184,5x5,5
Referencia: 1208
MARCA:    HONDA
CILINDRADA:    1500
MODELO:    GOLD WING GL SE
SIDE:    R
OUTSIDE:    316
INSIDE:    184,5
THICKNESS:    5,5
Nº HOLES:    6
HOLES:    10,5
« Last Edit: March 09, 2017, 04:16:44 PM by 98valk (aka CA) » Logged
Pappy!
Central Florida - Eustis
« Reply #20 on: March 09, 2017, 09:10:06 PM »
and how much space does this give you, side to side, up in the fender between the nut guards and the tire?
« Reply #21 on: March 10, 2017, 07:25:34 AM »
I didn't measure anything since many have used this size before. I did do the nut guard mod.
I put a total of 75 miles on the tire yesterday. If someone told me a car tire was on I would not have know it.
« Reply #22 on: March 10, 2017, 06:52:19 PM »
That's a nice looking tire and with the new rotor, even better.
Thanks for the tire report, guess I just found my next CT cooldude
« Reply #23 on: March 10, 2017, 07:58:25 PM »
looks good even with the oem saddle bags on.  coolsmiley
I surmise with it being a 1 ply sidewall, that is the reason it is so responsive. I had 39psi in it.  Also running a set of I/S shocks for the first time. A lot to evaluate, need to get more miles in.
« Last Edit: March 25, 2017, 08:51:35 PM by 98valk (aka CA) » Logged
« Reply #24 on: March 24, 2017, 07:36:02 PM »
was able to put another 200+ miles on the tire trying different pressures.  42psi is not good, too much bump steer. Now right at 39 psi which I started out with, very responsive, very little bump steer. will try this pressure for few days.
picture is tread profile at 39 psi with the side stand on a 2x4, just barely leaning. The tire maintained the curvature of the tread as previously pictured before wheel was mounted on the bike.
« Last Edit: March 26, 2017, 08:56:34 AM by 98valk (aka CA) » Logged
Bone
« Reply #25 on: March 26, 2017, 03:55:18 AM »
Thanks for the update. My second GYTT has 38k on it I'm thinking of trying this Laufenn your using I like the rounded profile.
The GYTT is square shouldered  I must be used to it I seldom notice.
Bone
« Reply #26 on: April 07, 2017, 02:18:33 PM »
This is my 4th CT with the last 2 being GYTT. Must have grown accustomed to the square corners the GYTT has this Laufenn G Fit won't stand by it's self. Leaving the garage I could tell the difference. Extremely cold here I road 15 miles and put it away I wasn't dressed for our cold weather.
I checked before leaving the tire had 34lbs cold. I'll up that a little each time I go out and ride more miles we have warm weather forecast this weekend.
« Reply #27 on: April 17, 2017, 11:27:43 AM »
Ride Report;
The tire likes a cold tire pressure btwn 37-38 psi.  This keeps bump steer to maybe 2% once it is at operating temp.  same bump steer I had with the E3 it replaced.
In the twisties, it responds just like an m/c tire.
Std/Tourer w/ I/S tank, I/S shocks.
Very satisfied with this Dark Side tire.
DarkSideR
Pueblo, Colorado
« Reply #28 on: April 17, 2017, 01:40:37 PM »
Great report. Now just watch how the tire wears.
I'm not a big guy (180lbs) and usually ride solo. At 38psi my Hankook (very similar to your tire) wore unevenly. The center tread faster than the outisde tread on the shoulders. I have since bumped the pressure down to 36psi.
Hope this helps,
DarkSider  Cool
VRCC#34410
VRCCDS#0263
« Reply #29 on: April 17, 2017, 02:38:04 PM »
Hope this helps,
DarkSider  Cool
Thanks, Laufenn is a Hankook brand, probably same tire. http://www.laufenn.com/us/front/us_front/news/news_view.do?n_id=342
I'm about 210 geared up, usually solo also.
« Last Edit: April 17, 2017, 03:01:27 PM by 98valk (aka CA) » Logged
Bone
« Reply #30 on: April 17, 2017, 04:04:34 PM »
Have 800 miles on my Laufenn. Also running 38lbs. more than I've ever run on a rear. I'm pleased with the ride on rough pavement the GYTT was a more harsh ride.
« Reply #31 on: April 17, 2017, 04:09:31 PM »
how u like it so far? handling, etc.?
Bone
« Reply #32 on: April 17, 2017, 04:17:11 PM »
I like the tire handling is good. Haven't rode in any rain yet the tread looks like it will handle a lot of water. Wished I wouldn't have rode 2 GYTT. I'm in almost a flatland area so my riding is mild but almost 70 yrs.old mild is ok Smiley
« Reply #33 on: July 06, 2017, 03:29:35 PM »
Ride/mileage report.
   running 37 psi cold.  After 1500 miles getting perfect tire wear across the thread.  With RPMs lower by 200, getting a solid 2 mpg increase. Scraping pegs a lot less due to the increased ride height. This is being on same roads/curves at same speeds before this tire install.
« Reply #34 on: July 06, 2017, 06:02:03 PM »
I'm curious on this tire's diameter esp as compared to the ATT.  The latter gives me no bump steer at all, though I have had it on other tires. The ATT likes high pressure - run it at 43#. Behaves much better for me than it did at 38. On some other DS tires I liked the cushy ride of the lower pressure but I won't give up the great handling of the ATT. Really like the tall size for great mileage at speed. that 205/65 must be a tall tire.
« Reply #35 on: July 06, 2017, 08:29:27 PM »
Austone  26.9 OD  tread width 5.5"
Laufenn G FIT   26.5 OD tread width 6"
Side Stand Extension for Dark Side, low cost fix.
http://www.valkyrieforum.com/bbs/index.php/topic,93955.0.html
nomoreharleys
Like having your own personal rocket ship
« Reply #36 on: July 10, 2017, 06:23:45 AM »
This is great info, still trying to decide on my first CT and this sounds like a good option. With your MPG increase, I did some math and figured your fuel savings will pay for the tire at 15,000 miles. If the tire makes it to 30,000 miles your next tire is paid for. Pretty cool.
0leman
Klamath Falls, Or
« Reply #37 on: July 10, 2017, 07:05:34 AM »
I put the same tire on several months ago.   Have 4K on it now.  Handles great.  Not bad price for tire.   I am running it at 30 lbs.  May tire kicking it up a bit.
Toovalks
East Lansing,Michigan
« Reply #38 on: July 11, 2017, 04:57:30 PM »
A Question for all of you dark siders.... is slow speed/ parking lot handling easier or more stable on the CT than on an Avon  or E3 for instance???
« Reply #39 on: July 11, 2017, 05:55:15 PM »
same for me.   reducing the trail of 5.89 will make that type of handling better. larger dia rear tire decrease trail. running a 130/90-17 rear tire on front reduces the trail, smaller dia then OEM tire actually there is no tire avail that is some dia as the OEM and the profile of that tire allows easier handling.
Pages: [1] 2 3   Go Up
