February 12, 2026, 02:24:40 PM *
Author Topic: Silicon Rubber or Equal for Rattle  (Read 1144 times)
Fazer
« on: October 11, 2016, 05:33:54 AM »
On my Tourer, the metal bag support rests on top of the truck stacks and when I hit a bump, I get an annoying rattle.  I am thinking a small piece of high temp rubber gasket to withstand the heat of the exhaust would be just the ticket.  I see listings for rubber gasket material on Ebay, but there has to be a simple source for something like this.  My plan would be to use double stick tape to the bottom of the saddle bag support where it hits the exhaust.
Any thoughts?
Nothing in moderation...
big poppa pump
San Antonio, TX
« Reply #1 on: October 11, 2016, 05:47:56 AM »
It shouldn't be rattling in the first place. Something is loose.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
« Reply #2 on: October 11, 2016, 06:39:05 AM »
Is it the black pan/guard that's screwed to the bottom of the bag mounts? If so, I would assume the contact is at the very back end where it curves down....mine did the same on one side. The cure....my jig saw with a metal cutting blade. I cut off the back end where it came in close contact on one side and touched on the other, been that way for a dozen years with no adverse results for exhaust heat. Just be sure to paint the edges where you cut to prevent weathering.
« Reply #3 on: October 11, 2016, 09:31:20 AM »
check the chrome exhaust heat shield next to the rider's right foot peg for looseness.
Fazer
« Reply #4 on: October 11, 2016, 10:55:22 AM »
Good suggestion John.  That is exactly where it is hitting.
Big Poppa--how ya doin'?  It's very tight, not loose anywhere.  It hits, just line John said his did when hitting sharp bumps--not swells, like spreed bumps, although I suppose if you hit them hard enough it would flex enough to rattle.
98Valk had a good suggestion about the heat shield, but I have already chased that one down.  I had to buy a couple of rubber sleeves that cover the tabs where they attach to the rest of the system.  No rattle there.
mark81
Cincinnati Ohio
« Reply #5 on: October 11, 2016, 04:19:33 PM »
You could do this Greg
http://www.horseapple.com/Valkyrie/Tech_Tips/Interstate_Stacks/interstate_stacks.html
Are you sure your exhaust isnt tweaked slightly?
Easy place to source heat resistant silicon sheet is a pot holder. Another option might be a kevlar oven mit like "the OveGlove"  look in the kitchen section at target or meijer and I'm sure there will be something
1997 Honda Valkyrie
1981 Honda CB750 Custom
« Reply #6 on: October 11, 2016, 04:35:24 PM »
My interstate heat shields (below bags) got rattley.  And where they touched the exhaust truck stack tips, they corroded a bit (just narrow lines).  I took my bags off, and bent the heat shields up (just) a bit in the back.  When I put the bags back on, I had to push them down hard to get the bolts tapped (pushing the bent up shields down a little), and every time they come off, I have to do some pushing again.  But no more rattle.
Anything like rubber or silicone you stick down there is going to melt, smell and make a mess.  A better spacer would be a chunk of steel/nut/washers/small rock, but bending them up a bit in back does the trick.
You are not trying to cushion the heat shields from the stacks, you are moving the shields above the stacks (like only a couple millimeters).
« Last Edit: October 11, 2016, 04:42:36 PM by Jess from VA » Logged
« Reply #7 on: October 11, 2016, 08:10:58 PM »
This.^^^^^^^
