February 12, 2026, 02:40:23 PM *
Author Topic: Loose Rear Fender  (Read 1416 times)
Jruby38
Oxford Mass.
« on: October 11, 2016, 02:43:09 PM »
I can wiggle the bottom half the rear fender. Is this normal?  The hex bolts are tight but I still have a little flex at the joint. Any brace rig?
« Reply #1 on: October 11, 2016, 03:13:45 PM »
Kinda hard to know what you mean by a little flex.
http://www.procaliber.com/oemparts/a/hon/506c2f33f870023420a31b1e/rear-fender-grab-rail
The rear section of the fender is held by the 2 grab rail bolts and a bolt (#15)  that holds the rear seat back bracket, to it, and the rear fender front section.
Jruby38
Oxford Mass.
« Reply #2 on: October 11, 2016, 05:00:33 PM »
The rear section will move at the joint if I give the bottom a lift. Is that normal? The bolts are tight.
« Reply #3 on: October 11, 2016, 05:12:21 PM »
No, the rear fender should not move.  Maybe move very slightly.
Is the bolt that holds down the rear seat tight?  If so, you could have a stripped welded nut on the back of the front rear fender. (what?)
I had that happen once and had to have a nut re-welded in place on the front rear fender.  My welder did a great job, as we were worried about the paint.
larue
Clermont,FL
« Reply #4 on: October 11, 2016, 06:09:16 PM »
If the little bolt hole is stripped and can't weld a nut there may be slip the bolt from the inside of the fender out and use a chrome acorn nut to tighten the top and have a nice finish
Jruby38
Oxford Mass.
« Reply #5 on: October 12, 2016, 05:02:53 PM »
Thanks, I check the seat bolt.
« Reply #6 on: October 12, 2016, 05:48:29 PM »
One of my bikes had a loose rear lower half fender for several years.  It's weight holds it down, but it would flex up/out a quarter inch or more on hard bumps or lifting it by hand (no side to side movement).  I was worried that this would get worse over time, but it did not as far as I can tell.
When I was in there for a tire change two years ago, I got under and tried to tighten it up, but everything was as tight as can be.  There was also some corrosion, but not bad.  I did not have time to diddle with it further before replacing the tire.
Big Bill (BF) worked on my bikes after Morgantown, and I asked him about it.  He tried to explain the problem under there (all writing), but I didn't understand (metal fatigue?).  I dumped out my big bolt and nut can,  and he used a poly or urethane washer or spacer to snug up the mount enough to stop the movement.  This may not be a permanent solution.  Sorry I cannot be more specific.
I picked up a perfect condition black rear fender (upper and lower) at Inzane this year.  Just in case.
Ramie
2001 I/S St. Michael MN
« Reply #7 on: October 13, 2016, 05:36:44 AM »
Is it possible you have rear fender fatigue?
http://www.valkyrieriders.com/shoptalk/Known%20Valkyrie%20Problems.htm
Jruby38
Oxford Mass.
« Reply #8 on: October 13, 2016, 06:34:23 PM »
All set now, thanks Hook. I tightened the 8mm bolt that was loose. I had no idea that little bolt is all that holding the bottom section. It took PB Blaster and gun Brakefree CLP to get it freed up.
« Reply #9 on: October 14, 2016, 03:30:51 AM »
Actually, the fender is held on by the two grab rail bolts with the small bolt keeping it in place. Smiley
h13man
Indiana NW Central Flatlands
« Reply #10 on: October 14, 2016, 08:08:30 AM »
The rear seat bolt is a chromed M6 with a 8mm hex head flange bolt. I suggest replacing it with a standard SS M6 and flat washer and a tad of antisieze for corrosion purposes. Yes its not chrome but who in the heck looks at it? I don't. I also use a thin rubber washer between the seat bracket and the fender.
Jruby38
Oxford Mass.
« Reply #11 on: October 14, 2016, 03:29:14 PM »
Yes H13man. I removed the hex bolt and put it back with a ss washer and anti seize.  I have a nylon tourpack and it covers the bolt anyway.
