February 12, 2026, 06:40:53 PM *
Author Topic: Changing my Water Pump  (Read 1333 times)
« on: October 21, 2016, 05:10:26 AM »
I'm changing out my Water Pump this weekend.
I've looked through several threads on the subject.
I've discovered that I need to drain the oil before removing the old pump.
Is there any other things that I should be aware of?
« Reply #1 on: October 21, 2016, 05:24:51 AM »
Yes start the engine first thing, get them bolts and the block warm.  High chance of breaking bolt, worse when cold.  Tap on the socket And extension with a small hammer before attempting to loosen, this is to help break loose any corrosion.
« Reply #2 on: October 22, 2016, 07:18:33 PM »
Changing out the water pump went off without a hitch today.
Warming it up a bit before loosening the bolts was probably a really good idea.
They were very rusted when they came out.
I was hesitant about reusing them but since I didn't have new ones and I didn't want to wait another week, I went ahead and reused them.
I tried something to remove the rust that turned out to work pretty well.
I let them soak for awhile in vinegar.
The vinegar really did remove a lot of the rust.
I finished cleaning them with a wire brush and sprayed them with a liberal coating of WD40 before reinstalling them.
Harryc
Sebastian, Fl
« Reply #3 on: October 22, 2016, 07:23:43 PM »
Next time consider anti-seize. it will remain in place much longer than WD-40.
58Woody
Chanhassen , Mn.
« Reply #4 on: November 03, 2016, 03:55:44 AM »
Any one ever used "fluid film" ?
Instead of "anti seize".
Be not afraid. Only believe.
Hooter
S.W. Michigan
« Reply #5 on: November 03, 2016, 05:31:20 AM »
I've used The Works to clean / soak parts in.
« Reply #6 on: November 03, 2016, 07:47:21 AM »
WD40 won't help in this application. It evaporates and leaves clean dry metal behind. Remove the bolts (one at a time) and use Never Sieze on the threads.
falconbrother
« Reply #7 on: November 04, 2016, 11:56:50 AM »
I usually just brush some 10-W30 or whatever is handy in motoroil when installing bolts like that.  I haven't used real anti seize in years.  WD-40 doesn't work all that well.  It works best at removing glue and goo.  The Walmart spray lube works better than WD-40 for actual lubrication.
$ Ball
« Reply #8 on: November 05, 2016, 05:40:07 PM »
What was wrong with water pump. and how many miles on it,
« Reply #9 on: November 05, 2016, 05:56:22 PM »
Man, I got only one water pump.  It's kind of old and beat up, but I don't want a new one.   Roll Eyes
RudyF6
Chelsea, Michigan
« Reply #10 on: November 08, 2016, 11:25:46 AM »
Did a w/pump on one of mine this past spring. On advice of a tech, I ordered new bolts with the pump. Mine were corroded almost 1/2 their diameter  Shocked Got lucky and they didn't break coming out!
You can never be lost if you don't care where you're going!
98 "Tourerstate" (Std. with I/S bags/trunk)
98 Tourer solo ride
81 CBX
