December 17, 2025, 10:29:53 PM *
Author Topic: need some electrical advice from you experts  (Read 2067 times)
DanL
Manchester, NH
« on: October 28, 2016, 06:50:42 PM »
I have had my gerbing jacket, gloves & socks for over 15 years.  The Gerbings have SAE plugs.  I went for a ride yesterday and when I had the jacket's plug connected to the controller the plug began to overheat and but I didn't notice it until  about 20 minutes into the ride.  I ended up with a small burn on my stomach because the plugs burnt me through a tee shirt.
My question is why did this happen and how can I fix it?
The Jacket & gloves did work as normal and kept me warm.
Dan
ybnorml
« Reply #1 on: October 29, 2016, 02:14:23 AM »
Is this the SAE plug that the controller connects to Dan ?? (SAE plug permanently attached to coat liner)
I know Gerbing "used" to carry a lifetime warranty....not sure now where the company has changed ownership.
Maybe try whatever contact #, email address, or mailing address you have....They may
replace whatever the wiring / plug that has become defective.
*this is just a stab in the dark looking for a remedy, by no means am I an expert*
Altho; I can find chipolte smoked mussels at the drop of a hat !!!
Andy Cote
Windham, Maine
« Reply #2 on: October 29, 2016, 05:05:35 AM »
I posted a note on the tech board.
There is a recall in the liner but company has a new owner so not sure how supportive they will be.
The original designer, Gordon Gerbing, has opened a new company and he might be able to help.
2015 Goldwing, basic black
Previously: 2000 Valkyrie Interstate, 1997 Valkyrie Standard, 1988 GL1500, GL1200 Standard, GL1200 Interstate and many other Hondas
holmes
« Reply #3 on: October 29, 2016, 06:42:26 AM »
couldn't you just cut the SAE plug off and splice in a new one?
http://www.solarseller.com/low_voltage_dc_pumps__lvm__teel__accessories__plugs_and_extensions.htm
DanL
Manchester, NH
« Reply #4 on: October 29, 2016, 07:19:07 AM »
Thanks all.  It is the plug from the controller & and the jacket liner. they really heat up Angry
I have sent an email to the company but so far it is no response.
Chris I was thinking of cutting the plugs and replacing them but how would that prevent the new plugs from heating up?  Do you think the SAEs are just worn out?
Dan-bury
Danbury CT
« Reply #5 on: October 30, 2016, 04:10:04 PM »
A bad connection can cause heat, but usually will draw more amps and blow the fuse.  Although most folks have a 30 amp fuse that takes a good short to blow!
As said, you can cut out the bad section and wire in a new one if the rest of the electrics are in good shape.
One a side note,,, If you look to replace the Jacket I have a New Style Gerrbing Jacket liner, I bought at the end of last year, for sale.
I have spent most my money on Motorcycles and Women, the rest I just wasted.
DanL
Manchester, NH
« Reply #6 on: October 30, 2016, 06:15:05 PM »
and it hasn't blown, that's why I'm a little confused.
I did receive a reply from the new owners of Gerbing and they asked me to send them the controller & jacket to be tested & fixed.  I'll send them off tomorrow and see when I get them back.  Wink
ybnorml
« Reply #7 on: October 31, 2016, 12:54:31 AM »
Hope it's a speedy repair Dan.....
DanL
Manchester, NH
« Reply #8 on: November 01, 2016, 08:02:17 PM »
let's hope the weather stays like this until I get my jacket & controller back - FIXED  Cheesy
I really can't complain, how many pieces of electrical gear can last 15+ winters?  Wink
ybnorml
« Reply #9 on: November 02, 2016, 01:09:09 AM »
That was the reason I purchased my Gerbing heated coat liner Dan...
Paid a little more than some off brand, but in this case "quality" was the deciding factor.
Their 'warrantied for life' claim is hard to pass up.
Hopefully you will receive your heated liner before the weather turns.....
15 years and the company will repair / replace any electrical problems....can't beat it !!!
holmes
« Reply #10 on: November 02, 2016, 02:49:11 AM »
Sorry for the delayed reply.  Obviously my first choice would be to have the manufacturer fix it under warranty but if they didn't step up then yeah, I'd just cut and splice in new ends to see if that solved the problem.
DanL
Manchester, NH
« Reply #11 on: November 02, 2016, 07:27:06 PM »
and after describing the problem and he confirmed what you other experts said: some broken wires on one side of the connection was causing resistance which in turn caused the plug to overheat.  When I said the 15 amp fuse didn't blow, he said that was because the plug was probably designed to only take 4 or 5 amps. I guess that sounds logical but I'm no expert... as you all know  Wink
