July 10, 2025, 09:01:35 AM *
Author Topic: Does CB module have to be Grounded ?  (Read 1388 times)
petevenne
Concord NH
« on: October 03, 2009, 05:25:38 PM »
Don't have room for CB under rack due to Tail light..Thinking CB putting in trunk. Any problens with that?? Does CB module need a ground?
« Last Edit: October 03, 2009, 05:31:28 PM by petevenne » Logged
DFragn
« Reply #1 on: October 03, 2009, 10:13:32 PM »
No, the case doesn't need an independent ground.
petevenne
Concord NH
« Reply #2 on: October 04, 2009, 12:06:54 PM »
Worked like a champ, was able to squeeze it in under truck even with tailight in there.. Now does any body have the CB user manual?? Scanned or is it online somewhere??
Thanks, Pete
Chrome
London Ontario Canada
« Reply #3 on: October 04, 2009, 01:02:20 PM »
Hey Pete Send me your address  to  swontvrcc@sympatico.ca and will get a disc in the mail to you.
Happy Trails Adrian(Chrome) V
2001 Valkyrie I/S
1999 Valkyrie I/S
1998 Ace Tourer
1984 V45 Sabre
1976 CB 750 SuperSport
1969 CB 750 Chopper
Bagger John - #3785
« Reply #4 on: October 04, 2009, 06:55:13 PM »
I cut the divider out of my I/S' battery box and mounted its CB in the space, using a pair of fitted, closed-cell foam wedges to hold it in place. The transceiver is tilted front-to-back and is mounted with the wires exiting the unit towards the left. Has worked well for 8 years now.
petevenne
Concord NH
« Reply #5 on: October 05, 2009, 05:39:49 AM »
Mine is OEM radio and it came with original mounting bracket that bolts under trunk.. About a 1/2 hour install..
