January 28, 2026, 03:21:49 AM *
Author Topic: ok, I need diagnostic help?  (Read 7836 times)
COOK'n in Utah
« on: March 04, 2009, 11:53:10 AM »
My beloved valk is leaking oil.   Cry  It appears to coming out of the left side cylinder head cover and/or out of the gear shift shaft going into the engine.  Not allot of oil, but getting worse. My first instinct is the gasket for the head cover, but there is not allot of oil behind the cover (or at least there shouldn’t be   ???).
GUESSES ?
TIA
COOK’n
Shotgun
Canadian Lakes, Michigan
« Reply #1 on: March 04, 2009, 12:06:08 PM »
It's probably the seal around your gear shift shaft.  It's an easy fix.  If you check the archives, you should be able to fing it.  I would have done it for you but I'm not sure how to get to the archives now that the tech board has been changed.
COOK'n in Utah
« Reply #2 on: March 04, 2009, 12:21:22 PM »
Thank you sir... Cool
« Reply #3 on: March 04, 2009, 12:44:38 PM »
Yes I agree with shotgun. Daniel Meyer has a good write up on his pages.  Lips Sealed
COOK'n in Utah
« Reply #4 on: March 04, 2009, 12:51:59 PM »
Just found that write up from Daniel in the archive.
THANKS to you and Mr. Meyer
COOK'n  Cool
Daniel Meyer
The State of confusion.
« Reply #5 on: March 04, 2009, 02:19:51 PM »
COOK'n  Cool
You are most welcome!
Shifter Shaft Seal replacement
CUAgain,
Daniel Meyer
