April 30, 2026, 07:24:02 AM
1800 Tech Board
I need torque specs
Topic: I need torque specs (Read 2744 times)
bscrive
Ottawa, Ontario
I need torque specs
December 12, 2016, 05:24:24 PM »
Hi guys,
I need the torque specs for the front axel bolt and if there is a certain way it has to be torque down.
I had a manual, but I downloaded it on my old laptop that is in the recyclers now.
Re: I need torque specs
December 12, 2016, 05:43:04 PM »
Place the front wheel between the fork legs.
Insert front axle from the left side until fully seated.
Tighten axle bolt (59 N-m, 44 lbf-ft)
Tighten right axle pinch bolts (22 N-m, 16 lbf-ft)
Install both the brake calipers
Hold on the brakes and pump the forks some.
Tight the left asle pinch bolts (22 N-m, 16 lbf-ft)
bscrive
Ottawa, Ontario
December 12, 2016, 05:50:38 PM »
Thanks Mike.
