February 12, 2026, 08:58:17 PM
Rear speakers and wiring
Topic: Rear speakers and wiring (Read 977 times)
8post96
December 22, 2016, 01:01:02 PM »
Hey, just wanted to say thanks for the timing belt tips, it came out great. Thank God!!. I was hoping someone put speakers in the trunk of their interstate. I ran mine from the right side panel up to the trunk, I'm not sure where to-go into the trunk and bring the wires to the speakers. Any info would help!!
Re: Rear speakers and wiring
December 22, 2016, 05:12:52 PM »
Try these.
http://www.valkyrieforum.com/bbs/index.php/topic,10426.0.html
http://forums.delphiforums.com/n/main.asp?webtag=valkyrie&nav=messages&msg=12890.1&prettyurl=%2Fvalkyrie%2Fmessages%3Fmsg%3D12890%2E1&gid=2126664552
A search may turn up others. There has been posted the rear speaker wire harness. I forget where the plug in.
Dusty
Mill Bay B.C.
December 22, 2016, 07:44:27 PM »
There is a hole in the bottom of the trunk the wires will feed into. You will need to separate the inner and outer trunk to drill a hole in the inner trunk by the right trunk hinge. Then drill a matching hole in the trunk lid. Drill a hole behind the right speaker pod. All the speaker wires go through the holes and the left speaker wires are fed behind the backrest to the left speaker.
As Bikerboy points out the factory way is different from my installation. I just described how my installation is routed.
Dusty
Last Edit: December 23, 2016, 06:31:15 AM by Dusty
bikerboy1951
Grand Forks, ND
December 23, 2016, 02:08:58 AM »
In the original installation instructions the wire ran up the front of the trunk on the outside and was held in place with clips. It was never run into the trunk.
Brad
