January 29, 2026, 09:13:38 PM *
Author Topic: What tool?  (Read 2023 times)
fiddle mike
Nothing exceeds like excess.
Corpus Christi, TX
« on: October 07, 2009, 10:08:01 AM »
I want to clean out all my crankcase vent plumbing.  I need to remove the drool reservoir and it appears to be attached to the back of the ignition switch. The switch looks like it's fastened with a star drive bolt.  I don't want to buy a set if I can buy or borrow the correct one.  Any insights?
DFragn
« Reply #1 on: October 07, 2009, 10:22:02 AM »
That's a Torx driver tip that's required. I believe the Torx head screw is 6mm, but unsure of Torx driver size. They're available at any hardware store for a buck or two.
Why do you want to do that? Is the Dragn Drool not flowing to the drain out cap?
fiddle mike
Corpus Christi, TX
« Reply #2 on: October 07, 2009, 10:34:47 AM »
Thanks.
The removal is mostly cosmetic.
In the past, I've put K&N pods on Valks, removed the air box and installed a K&N breather filter.  My guru had been running a '97 that way for, probably, ten years.  I intend to cap off the air box where the hoses connect.
« Reply #3 on: October 07, 2009, 12:06:52 PM »
20 years ago my father-in-law needed a torx to adjust his headlights... we fumbled around and
made do with something or other... so I got him a torx set that Christmas...he passed about 10 years
ago, that torx set (unused) ended up with me... I replaced my ignition switch this weekend, and when
I got the cover off, there were those two torx screws staring at me... it was very satisfying having
the right tool!
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #4 on: October 07, 2009, 12:10:35 PM »
Cheap investment http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=35187
fiddle mike
Corpus Christi, TX
« Reply #5 on: October 07, 2009, 12:14:29 PM »
Thanks, I'm there!.
fiddle mike
Corpus Christi, TX
« Reply #6 on: October 07, 2009, 12:27:04 PM »
  Roll Eyes "Star drive"? I'm going to have to lay off the late-night fiction movies. laugh
Larry
Northeastern BC, Canada
« Reply #7 on: October 07, 2009, 04:31:52 PM »
You don't have to worry about a star drive, thes bikes run on impulse!  cooldude
HOZ
If it an't broke, don't fix it
Arlington, Wa.
« Reply #8 on: October 10, 2009, 12:21:48 PM »
A lot of times in a pinch I have used a Allen wrench, it will also work.
VRCC #1555
98' Tourer (Black) 157,000mi
99' I/S (Green & Silver) 45,700mi
