November 27, 2025, 03:12:50 PM *
Author Topic: Plug  (Read 1133 times)
8post96
« on: December 23, 2016, 02:17:48 PM »
Does anyone know where the speaker plug is located for the rear speakers, and what it looks like?
I have a 99  Valkyrie I/s thanks
« Last Edit: December 23, 2016, 02:31:49 PM by 8post96 » Logged
Novavalker
99 Interstate/2017 Goldwing
« Reply #1 on: December 23, 2016, 04:22:36 PM »
Rear speakers are not standard equipment.
Make sure there are speakers inside the rear pods.
« Reply #2 on: December 23, 2016, 04:58:18 PM »
The rear speaker plug is under the right side cover. Big bike parts (I think) has a harness to duplicate the factory harness. Try J&M out of Tucson for a harness too.
« Reply #3 on: December 23, 2016, 05:11:54 PM »
When I am in doubt, I like to go to ebay and look up the park in question, and look for one posted with the pictures that show what I am looking for.
Shows 2 flat connectors, but they are mains, blue and green. I see the ant input. The 3.5mm aux jack. Then the 2 large circler plugs.
I suspect that the harness we are looking for is part of the main wire harness. The fiche should help here.
Also the Service Manual, you do have it do you not? Also the wiring schematics, I think in the Shop Talk.
« Last Edit: December 23, 2016, 05:16:26 PM by gordonv » Logged
8post96
« Reply #4 on: December 23, 2016, 06:44:02 PM »
I have the Clymer manual, it doesn't have the rear wiring. I purchased the harness from Electrical Co next ions.com. I found then on this site. I have the speakers to put in the trunk. The harness I have has a square plug with 4 flat prongs inside. I can't locate the mate to it under the right side panel.
« Reply #5 on: December 23, 2016, 07:30:24 PM »
Buy a Service Manual. In the mean time, a PDF copy from here.
http://valkyrienorway.com/download.html
From Rattlebars
http://www.rattlebars.com/valkfaq/schematics/rpage10i.html
Sheet S8
The wire diagram looks like there is a 4 pin connector. 4P Mini Black.
« Reply #6 on: December 24, 2016, 05:22:54 AM »
Can't help you with this issue and looks like you have plenty (help)  Smiley
Did you resolve this issue?
http://www.valkyrieforum.com/bbs/index.php/topic,91955.msg910650.html#msg910650
« Last Edit: December 24, 2016, 02:36:30 PM by Hook#3287 » Logged
8post96
« Reply #7 on: December 24, 2016, 06:44:20 AM »
Maybe it's me, I can't find it, I found the round one's, a flat white one with 3 holes, but not a square one, unless I have the wrong plug on my harness. Can you post a pic of it please?
mark81
Cincinnati Ohio
« Reply #8 on: December 25, 2016, 08:43:02 PM »
been a while since I added the speakers to my old interstate I think there was a plastic cover with a couple connectors in it. it is a square 4wire plug
1997 Honda Valkyrie
1981 Honda CB750 Custom
8post96
« Reply #9 on: December 27, 2016, 02:09:50 PM »
Thanks for all the help! Finally found the plug, it was pulled  up into the rubber sleeve. Thanks again.
