February 12, 2026, 07:00:32 PM *
Author Topic: Rear Brake Pad Question  (Read 1079 times)
Jruby38
Oxford Mass.
« on: December 28, 2016, 11:36:14 AM »
Has anyone tried rear brake pads on the front? I put Gold Wing rotors on the front and they are a little thinner than OEM.  I have been using kevlar organic pads and they are much better than OEM pads on the rotors but wear out faster, but they are cheep and stop better.
Grandpot
Fort Mill, South Carolina
« Reply #1 on: December 28, 2016, 12:26:04 PM »
Are you sure you want to mess around with the brakes like that?  You may be betting your life on it.
« Last Edit: December 28, 2016, 01:44:14 PM by Grandpot » Logged
« Reply #2 on: December 28, 2016, 02:58:36 PM »
There have been members who have done exactly what you are suggesting. Haven't heard of any problems.
Jruby38
Oxford Mass.
« Reply #3 on: December 28, 2016, 03:59:43 PM »
Thanks Meathead. I figure there is plenty of room by how far the pistons are out.  Grandpot, the kevlar pads are 100 times better then OEM for stopping power.
« Reply #4 on: December 28, 2016, 04:22:43 PM »
Which Kevlar pads have you been using ? No issues of extra wear on the rotors ?
« Reply #5 on: December 28, 2016, 04:44:46 PM »
10mm which the rears are will work on the front.
However organic pads do not stop better than sintered-bronze pads which OEM is. many companies make sintered-bronze. SB is not hard on rotors. only race organic pads are better but they need to be hot to be better, something which does not happen on the street. the '97 valkyrie is still in the top 5 of all time for shortest stopping distance of all bikes tested using OEM pads.
please provide test results of kevlar pads providing shorter stopping distances. u won't be able to.
see here http://www.sixity.com/brake-pad-selection-guide
Jruby38
Oxford Mass.
« Reply #6 on: December 29, 2016, 07:10:00 AM »
Meathead. The place I bought from is D2MOTO.  Ordered 3 sets of rears. This will be my third set. I change tires each year and do my winter checkup. I pad slap while i'am there. The kevlar pads keep your rotors looking new with on ware, the OEM chewed my original rotors all up, and wore them down past min.
« Reply #7 on: December 29, 2016, 08:06:18 AM »
Thanks, I'll check them out.  cooldude
