February 12, 2026, 08:59:25 PM *
Author Topic: Ignition switch relocation?  (Read 2270 times)
Glaserbeam
Southern California
« on: January 11, 2017, 11:23:49 AM »
Almost finished sorting out the '02 fixer-upper I bought last month.
I don't like the stock ignition switch position.  Does anyone know of a relocation kit that would put it near the instruments, with a wire harness extension and bracket?  I see such kits advertised for Kawasaki Vulcans, but not for the Valk.
Thanks.
Ken
Grandpot
Fort Mill, South Carolina
« Reply #1 on: January 11, 2017, 11:52:35 AM »
Never heard of one.  Considering the population of our fine ladies, I doubt if any manufacturer of such devices would be interested.
« Reply #2 on: January 11, 2017, 12:31:18 PM »
Agreed.  It would be something you would have to make yourself, I believe.  Can't be that difficult in respect to the wiring, just have to build a 4 wire extension with two 4 prong (1 male, 1 female) connectors.   Mounting the switch could be a challenge.  Seems doable.
« Reply #3 on: January 11, 2017, 03:21:34 PM »
I would wait a while before doing that. I think you will find you get used to the ignition position pretty quick.
Glaserbeam
Southern California
« Reply #4 on: January 11, 2017, 04:17:30 PM »
I can't get used to not seeing my key while riding (and the tire pressure monitor hanging on my keyring) ... and I wouldn't be a good mechanical engineer if I didn't want to modify my environment to suit my needs  Smiley
WintrSol
Florissant, MO
« Reply #5 on: January 11, 2017, 05:15:06 PM »
I think acquiring the connectors may be the harder part. For a mount, you just need to fab a bracket, perhaps of polished stainless, with captive nuts to accept part #10:
http://www.partzilla.com/parts/search/Honda/Motorcycle/1998/GL1500CT+A/SIDE+COVER/parts.html
Glaserbeam
Southern California
« Reply #6 on: January 11, 2017, 05:56:04 PM »
Thanks for the tip.
« Reply #7 on: January 11, 2017, 06:27:54 PM »
I can't get used to not seeing my key while riding.
If bike is running the key is there cooldude
Just poking fun here. 2funny
You could never ride an HD then because the key would be in your pocket Undecided
« Reply #8 on: January 12, 2017, 07:38:13 AM »
Over the years there have been a number of rather unnecessary and useless mods attempted on the Valkyrie, most have been proven to be of little value. I'm with the earlier post re. "seeing" the key....if the bike is running, the assumption can be made that the key is on. The only "mod" of real value re. bike keys, or any other vehicle key, is to modify what you have on that key ring. Reduce it to just the ignition key if possible so as to not wear down the tumblers inside, caused by the excess weight banging around in the wind. I learned that from my first flight instructor when I was suddenly flying a glider because the excess wear on the ignition switch from all my keys caused the switch to turn just enough to cut it off. The silence was deafening.
Keep in mind, if you move the ignition sw. up near the neck of the bike, it becomes easier for someone to hot wire it.
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
« Reply #9 on: January 13, 2017, 06:18:24 AM »
Funny the 1800c has the key on top and I can't get used to it..    For the 1500 I'm just glad the key is on the right. Isn't the Rune on the left? I know it is stupid but on the left would be awkward, like the first time when I was a punk kid that I traded rides for a couple laps around the field, my 125 Yamaha with a guy who had a 125 full taco
(Bultaco) and tried to start the freaking thing.   Like using a computer mouse for the first time.   2funny
I'm also one of those ones it just prefers to have one key and nothing else
HickoryNCInterstate
« Reply #10 on: January 13, 2017, 04:34:50 PM »
I was at Wing Ding a few years ago and there was a key vendor that had the key blank molded into a chrome knob, blends in with side of the motor..Best $20 I have spend on the fat lady
Harryc
Sebastian, Fl
« Reply #11 on: January 13, 2017, 05:47:37 PM »
This one? http://www.rattlebars.com/vtx/wingknobkey.jpg
http://www.rattlebars.com/vtx/vtx02.html
http://www.ebay.com/itm/Show-Chrome-2-428-Chrome-Radio-Knob-1988-2010-Honda-Gold-Wing-1500-1800-/261387391505?hash=item3cdbe71211:g:bS0AAOxy69JTAlDs&vxp=mtr
« Last Edit: January 13, 2017, 05:58:53 PM by Harryc » Logged
« Reply #12 on: January 14, 2017, 06:54:30 AM »
Not always, a member here this past September lost his key while riding on the DRU. It is possible that the ignition fails and let's the key come out while in the on position.
WintrSol
Florissant, MO
« Reply #13 on: January 14, 2017, 08:57:11 AM »
All the more reason to not have anything hanging from your key. Shocked
« Reply #14 on: January 14, 2017, 12:57:47 PM »
Pretty sure he said it was just a single key with nothing on it.
Paladin528
« Reply #15 on: January 19, 2017, 06:18:46 AM »
look at vintageconnections.com to see if they have the correct connector.  I have built harness extensions for my audio install and they carried the correct connectors so I did not have to cut into my main harness,
you can also try http://www.cycleterminal.com/index.html
« Last Edit: January 19, 2017, 06:20:22 AM by Paladin528 » Logged
mark81
Cincinnati Ohio
« Reply #16 on: February 09, 2017, 06:36:11 PM »
Just saw this and remembered this post.  Ya may be able to use this or adapt it to work on the valk
https://youtu.be/nv5y2ZL-Za0
1997 Honda Valkyrie
1981 Honda CB750 Custom
h13man
Indiana NW Central Flatlands
« Reply #17 on: February 10, 2017, 08:17:50 AM »
Due to weather conditions etc. I like the stock position best. I do believe Honda has this location down pat compared to neck location that other manufactures seem to keep doing but I've been riding Hondas for 43 yrs. Just a normal location for me.
