February 12, 2026, 08:59:38 PM *
Author Topic: new carb tubing and dead ends  (Read 1029 times)
N0tac0p
« on: January 20, 2017, 04:18:52 AM »
I know I have visited and bought things from a vendor found here, but can't find them now.  they had the oring kits, the dead ends with clamps......
please help...who is it?!
« Reply #1 on: January 20, 2017, 04:25:36 AM »
Probably this feller:
http://redeye.ecrater.com/
N0tac0p
« Reply #2 on: January 20, 2017, 04:35:36 AM »
yup redeye!
thank you so much
N0tac0p
« Reply #3 on: January 20, 2017, 04:38:48 AM »
hmmm, perhaps another as well.  I don't see the dead end plugs and clamp kit
big poppa pump
San Antonio, TX
« Reply #4 on: January 20, 2017, 05:23:00 AM »
http://redeye.ecrater.com/p/3301919/three-vacuum-caps-honda-valkyrie
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
Pappy!
Central Florida - Eustis
« Reply #5 on: January 20, 2017, 06:28:43 AM »
BonS also has some very good quality vacuum caps.
« Reply #6 on: January 20, 2017, 06:59:46 AM »
« Reply #7 on: January 20, 2017, 07:54:01 AM »
I replaced mine with OEM Honda ones which seem pretty studly.
A ~half-inch chunk of the same tubing you use for everything else
with an appropriate short bolt in it is also good.
-Mike "BonS and the redeye guy all the way  cooldude  "
« Reply #8 on: January 20, 2017, 09:53:46 AM »
I took a vac nipple down to Ace and bought 3 bolts and copper washers to plug the unused vacuum ports. Then the vac nipples were placed under the seat in a ziplock bag.
Pappy!
« Reply #9 on: January 22, 2017, 11:10:35 AM »
Thats great!.......until you need to sync the carbs.
« Reply #10 on: January 22, 2017, 11:25:14 AM »
The nipples screw right back in. I'm sure its a good thing - syncing carbs - I bet I need to.
But I've never done it in 10 years.
