February 12, 2026, 10:19:16 PM *
Author Topic: Corrosion on positive terminal  (Read 970 times)
cogsman
Newmarket, Ontario, Canada
« on: January 21, 2017, 10:40:22 AM »
Hi All,
When I disconnected the battery for the winter I found a greenish sludge/powder around the positive connector.
To be clear about how everything is connected:
- I have the main wiring spade against the terminal
- I have the positive lead from my Eklipes accessory terminal on top of that
- Then comes the bolt
No electrical issues at all with the bike, but never noticed this before. There isn't a lot of the green stuff, but I certainly don't want to create future issues.
« Reply #1 on: January 21, 2017, 02:25:03 PM »
Baking soda mixed with a little water to make a paste will clean it up. Or a can of coke
Harryc
Sebastian, Fl
« Reply #2 on: January 21, 2017, 02:46:44 PM »
Here's what I do. Clean/wire brush all connections. Put them back together and spray with this stuff. Problem solved.  http://shop.advanceautoparts.com/p/crc-battery-terminal-protect-7.5-oz.-05046/7071027-P
« Last Edit: January 21, 2017, 02:48:16 PM by Harryc » Logged
« Reply #3 on: January 21, 2017, 03:31:13 PM »
What is it? It is the acid from the battery. Corrosion. The baking soda is the opposite Ph value, and will neutralize it.
« Reply #4 on: January 21, 2017, 04:48:24 PM »
Technically Baking soda is sodium carbonate. It's not a high pH to counteract the acid. Baking soda is in a class called a pH buffer. It tends to neutralize Ph whether it's low(acid) or high(caustic).
cogsman
« Reply #5 on: January 21, 2017, 05:17:00 PM »
Great thank you! Will this continue to happen or is there something I can do to keep it from happening?
Firefighter
Harlingen, Texas
« Reply #6 on: January 21, 2017, 05:23:52 PM »
A little moisture can get into the connection which will cause a green/white corrosion. Some batterys seep a small amount of acid sometimes and a battery with a dirt build up on top will sometimes have corrosion problems and discharge also. I would do like the others say, clean it up and use a battery spray to keep it clean. Make sure and shine up your connections.
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
Firefighter
Harlingen, Texas
« Reply #7 on: January 21, 2017, 05:34:38 PM »
Could have been only a one time event, unless there is something like an acid leak that is causing it. I have seen car batterys that will continue to produce that green stuff. Clean tighten and spray, then see what happens.
1978 Honda 750
Cracker Jack
« Reply #8 on: January 21, 2017, 06:16:43 PM »
Actually, I think it's sodium Bicarbonate. cooldude Not that it matters.
