Stanley Steamer
« on: October 09, 2009, 10:25:34 AM » |
We had a new Trane heating and AC system installed about 4-5 yrs ago and they installed a CAP 100 Filter unit into the system.....it uses a large 5"x 20"x 25" filter along with the normal 1" filters in most systems..... I had been ordering one of the large filters directly from Abatement Technologies, but they no longer sell to private homeowners...  ....they told me to go through the installer...the last time I asked them, they wanted to install it if they sold me one almost doubling the price.......I can do that myself, it takes less than 5 mins to do it once I have the filter.....the filter cost me about $48 + S&H last year.... My question is if any of you guys out there have one of these you could sell me??.....it's silly for me to pay twice the $$ for such an easy replacement job.....Here's a link to what unit I have....I don't have the UV light.....so, I don't need that piece....Thanks http://www.abatement.com/residential/cap_50_100.htmSpec sheet... http://www.abatement.com/residential/pdf/cap100_technical_specs.pdf
Stanley "Steamer" "Ride Hard or Stay Home"
« Reply #1 on: October 09, 2009, 10:33:53 AM » |
Could ya just put in 5 - 1" filters instead?
Stanley Steamer
« Reply #2 on: October 09, 2009, 10:39:24 AM » |
Could ya just put in 5 - 1" filters instead?  Oh Lawd.....you must be a YANKEE....No, you can't do that!!.....on a related matter, I once told an old GF I could give her 12"....in a couple of installments....  ...  ...
« Reply #3 on: October 09, 2009, 11:04:39 AM » |
Could ya just put in 5 - 1" filters instead?  Oh Lawd.....you must be a YANKEE....No, you can't do that!!.....on a related matter, I once told an old GF I could give her 12"....in a couple of installments....  ...  ...   I've seen some BA filters at my hardware store. Did you try there? I'm not sure what your filters look like, to lazy to open your links!
Jack
Benton, Arkansas
« Reply #4 on: October 09, 2009, 11:11:40 AM » |
Find a local HVAC supply house. They should be able to sell you one for half that. We sell them for $26.44 including tax but freight would kill you.
You might try Atlanta Supply. I think they have free freight and the cost would be less than $30. 1-800-972-5391
« Last Edit: October 09, 2009, 11:17:00 AM by Jack »
Mickey Runie
« Reply #5 on: October 09, 2009, 11:30:29 AM » |
hillbilly
« Reply #6 on: October 09, 2009, 12:55:15 PM » |
Us YANKEES don't know much about all that new fangled stuff. We ain't got nothin but winder fans and coal stoves.  Ain't got remote controlled TV either! When I get too lazy to tell my wife to get up and change channels I'll quit watchen it.
« Last Edit: October 10, 2009, 09:16:14 AM by hillbilly »
MNBill
« Reply #7 on: October 09, 2009, 01:58:43 PM » |
I got mine at the local Fleet farm for about $25, I agree with the above post, check the local hardware stores
MNBill SE Minnesota
junior
« Reply #8 on: October 09, 2009, 02:49:23 PM » |
Could ya just put in 5 - 1" filters instead?  Oh Lawd.....you must be a YANKEE....No, you can't do that!!.....on a related matter, I once told an old GF I could give her 12"....in a couple of installments....  ...  ...  hey stan you want to remember................... if it wernt for us yankees,you boys down in Georgia would still have them folding hand fans.
Chillerman
« Reply #9 on: October 09, 2009, 04:06:30 PM » |
Stanley, I have the same size filter in a Carrier electronic air cleaner for my furnace. The distributor charges $50-$60 bucks for a replacement but the local Home Depot sells the same size (I don't know about the specs) for far less.
Stanley Steamer
« Reply #10 on: October 09, 2009, 05:01:48 PM » |
Thanks guys....I have a couple of leads to follow now....
« Reply #11 on: October 09, 2009, 05:27:01 PM » |
Us YANKEES don't know much about all that new fangled stuff. We ain't got nothin but winder fans and coal stoves.  Us yankees don't even turn on the heat till round thanksgiving!  hoser
« Reply #12 on: October 10, 2009, 07:50:38 AM » |
Us YANKEES don't know much about all that new fangled stuff. We ain't got nothin but winder fans and coal stoves.  I got a coal burnin' winder fan.
Jack
Benton, Arkansas
« Reply #13 on: October 10, 2009, 08:23:32 AM » |
I'm not an HVAC guy. Based on a recommendation a few years ago, I went with a high tech super duper filter. End result was; not enough air flow to the heater unit. Ran for months in an overheated mode due to lack of air. Burned up some pricey parts. I now use the buck-apiece filter from the local hardware store. Change monthly. Six or seven bucks per year. Works for me. Ymmv,
Sheets, that is a very important aspect of HVAC. A system is designed for certain airflow. When the airflow is impeded, problems occur. That isn't something advertisers tell you in large print. (Also, many folks don't ever change air filters and cause problems due to impeded airflow.) I was once told, "Better air filters block more air particles. A sheet of plywood will stop everything." If you are running a standard system, a Merv of 7-9 is fine. If you have allergies, you may want a better filter but the system has to be designed to handle it.
