February 12, 2026, 10:19:08 PM *
Author Topic: Brake flasher relay  (Read 1163 times)
« on: January 29, 2017, 08:03:22 AM »
Up to my usual chromatherapy, gotta keep the neuralpaths greased.  When tinkering with the fuel system, transfer timer, was appreciating the tuning options of that timer - looked closer at the relay they make specifically for flashing the brakes.  This one has an accelerometer that detects how hard you are braking, and flashes the brake faster if you are braking harder.  An option I think we will see in cars soon.  It's really easy to install - just wire it in series on the brake line, and connect a wire to ground. It's programmable with options but is already setup with defaults so you don't have to program it.  It's really small - I Goop-glued it to the fender rail so it's covered by the seat and out of the way.  The extra white wires are for programming - not connected to anything. I connected mine to the Radiantz LED taillight only - not to the marker lights or Highlighter or trailer brake line which also indicate brakes applied.
From their web page at http://www.3rdbrakeflasher.com/brake-light-flasher-c-65/vehicle-brake-light-flasher-module-with-brake-force-monitor-p-183.html
The new generation of active flashers uses 3-axis accelerometer to measure vehicle braking force. Not only it could flash the light when brakes are first applied but it continues to monitor your vehicle braking force and flashes again once it detects medium or hard braking. It solves the problem when you apply very light brakes just in anticipation, like approaching intersection or driving downhill. Your brake light will come on as soon as you apply light pressure on the brake pedal and you might cruse like this for some time. Then the situation changes and you apply great deal of pressure on the brake pedal to stop. You vehicle is now really slowing down but the driver behind you sees no changes in your brake light since it continues to be solid on. He or she has no indication that you are really slowing down!!!  It will take some time for the driver behind you to realize the distance changes between vehicles to activate his brakes. That time is what separates you from the rear-end collision.
Devices like this are normally very expensive (100$ - 200$), but advances in microelectronics allowed us to design and build very affordable unit. It is very easy to install and configure. From the factory it comes with preset flashing patterns: blinking light six times slow upon initial braking engagement, two times slow during lockout period, six times fast during medium braking and sixteen times fast during hard braking. All those parameters can be adjusted by user as well and medium and hard braking trigger levels.
    Vehicle Brake Light Flasher Module with Brake Force Trigger.
    Multi mode adjustable flashing patterns.
             Lockout time from 3 to 30 seconds.
             Multiple flashing affects.
             One to twenty flashing cycles.
             Thirty different flashing rates from fast to slow.
    Independent configuration for medium and hard braking flashing pattern.
    Continues flashing mode with 4, 8, 12 and 16 second pause.
    Works on both LED and INCANDESCENT brake lights.
    Rated upto 100 watt (8 amp).
    Microcontroller and 3-axis accelerometer based for accuracy and reliability.
    Very small form and waterproof to fit any application. (25x16x4mm LxWxH)
    5 min installation (3 wires).
    Stop Alert comes with preconfigured configuration of 6 medium flashes during initial braking, 6 fast flashes during medium braking and 16 very fast flashes during hard braking.
    Out of the box Stop Alert is ready to be installed with no additional configuration needed.
    LIFETIME WARRANTY.
    Made in USA.
« Last Edit: January 29, 2017, 10:07:59 AM by MarkT » Logged
WintrSol
Florissant, MO
« Reply #1 on: January 29, 2017, 09:14:07 AM »
Interesting. You need someone to follow you around and review it. Cool
