November 27, 2025, 03:38:35 PM *
Author Topic: 1500 Goldwing Rear Spline Donor Unit - CHEAP  (Read 1324 times)
Valkpilot
What does the data say?
Corinth, Texas
« on: January 29, 2017, 06:09:53 PM »
Someone might want to jump on this.
http://gl1800riders.com/forums/78-classic-goldwings/332377-1500-final-drive-shaft.html
This isn't a bolt-on replacement for a Valk rear drive, but you can press the spline cup out of the donor unit and press it into your toasted one.
You might get a good pinion cup too, but the drive shaft won't work on the Valk.
I'd ask and see if he has the star hub too.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #1 on: January 30, 2017, 07:38:07 PM »
Drive shaft should work.
The GW GL1500 drive shaft was replaced with the ones from the Valkyrie. So they are the same, but I would think the Valk one is "better".
Valkpilot
Corinth, Texas
« Reply #2 on: January 30, 2017, 08:08:27 PM »
You sure you're not thinking about the u-joint?  I've got a GW unit and the drive shaft is a different length.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
indybobm
Franklin, Indiana VRCC # 5258
« Reply #3 on: January 31, 2017, 05:37:53 AM »
All Goldwing driveshafts are about 3/4" too long for the Valkyrie. As a side note, I have not bought a Goldwing 1500 Final Drive that did not come with the Drive Flange that was mated to it.
So many roads, so little time
VRCC # 5258
« Reply #4 on: January 31, 2017, 05:14:36 PM »
Yes, you're right, it was the u-joint that is the same. My Bad!
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #5 on: February 02, 2017, 08:06:28 PM »
This item was purchased
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
