February 12, 2026, 08:58:21 PM *
Author Topic: Interstate radio wires  (Read 943 times)
Capt Dan
« on: February 02, 2017, 01:04:27 PM »
I am hooking an amp and rear speakers on my Dragon and have notices a green and a white wire coming out of the wire cluster to the blue connector. These wires aren't hooked to anything however I got a wiring schematic from the rattlebars website that shows these wires going into the blue connector.
Are these just spare wires or has someone been monkeying with my wires? If I leave them as they are is something not going to work?
Bagger John - #3785
« Reply #1 on: February 07, 2017, 06:16:08 AM »
Which area is this connector located in - under the right side cover, around the triple clamp, ?
Capt Dan
« Reply #2 on: February 09, 2017, 07:08:36 PM »
Its coming out of the radio to the connector behind the right side cover.
BigM
« Reply #3 on: February 10, 2017, 09:22:24 AM »
I also have a ques. on the I/s radio. One pinned connector is for C.B. hookup. Top of battery. I noticed another pinned pig tail under the right side cover. nothing plugged into it. Any idea what that one is for?
« Reply #4 on: February 10, 2017, 06:06:43 PM »
I'm not sure, without looking or investigating, but I would first think the connector for the CB addition.
Paladin528
« Reply #5 on: February 15, 2017, 12:01:49 PM »
One DIN connector is for the CB and the other is for the CD changer in the Saddlebag.  Neither one is hooked up to anything on mine.  Sad
I also have one connector that is not hooked up to anything but I never looked that close to see what it was for.  its pretty corroded though.  Everything works so I will continue to ignore.
