February 12, 2026, 08:58:31 PM *
Author Topic: Gas leaking  (Read 989 times)
Cinco9
« on: February 09, 2017, 05:32:02 PM »
Anybody have a problem with gas leaking from the right side ?  valkyrie Tourer... haven't had a chance to jack bike up....just looking for some heads up ...Thanks
Harryc
Sebastian, Fl
« Reply #1 on: February 09, 2017, 05:36:44 PM »
Where on the right side? At the bottom of the bike or from the carbs? If it's from the bottom, check your carb bowl drain screws for tightness and/or missing or deteriorated o-rings.
« Last Edit: February 09, 2017, 05:39:19 PM by Harryc » Logged
« Reply #2 on: February 09, 2017, 05:51:13 PM »
There are a couple of places and reasons for a fuel leak.  How much are we talking here?
I'd suggest you pull the plugs and check for gas in one of the cylinders just to be safe.
I wouldn't try to start her until you rule out hydrolock.
If you can locate the leak by following the fuel line starting at the petcock, that would be the way to go.
Look at the fuel line T's, their O'rings have been know to dry up and weep some.  Usually they swell once gas starts flowing again and stop leaking.
« Reply #3 on: February 09, 2017, 05:59:45 PM »
Sounds like dried up o-rings on the fuel rails. The right side dries up first because of the side stand tilt. Let the carbs and rails fill with fuel for a day or 2. Hopefully that will stop it.  cooldude
Harryc
Sebastian, Fl
« Reply #4 on: February 09, 2017, 06:13:17 PM »
Off topic but I hope the OP understands the reason for this question. @meathead, if you were going to put the Valk in storage for say 3 months, would you drain the fuel out of the float bowls? Lets assume the fuel is treated with a stabilizer ...
« Last Edit: February 09, 2017, 06:16:08 PM by Harryc » Logged
« Reply #5 on: February 09, 2017, 06:17:27 PM »
Harry, this question is almost as controversial as what oil do you use and what CT is best. Smiley
I think the jury's still out.
I've done both and can't seem to see any difference, so now I just treat the gas with Stabul Marine and don't bother.
Harryc
Sebastian, Fl
« Reply #6 on: February 09, 2017, 06:20:10 PM »
Cool , this dried up o-ring thing had me scratching me head Bill. I did drain mine this winter, but I have not done it in the past on other bikes.  It was fun rebuilding those carbs, but I do not want to do it again anytime soon. Lol
« Last Edit: February 09, 2017, 06:32:55 PM by Harryc » Logged
« Reply #7 on: February 09, 2017, 06:28:23 PM »
Yeah, I said T's but I meant rails. uglystupid2
I've never had the issue.
I drained them every fall when I only had one, for a few years, then I thought, maybe that would promote the rubber drying out.
Then I swapped the jets to 38's and never did it again, just started treating the gas before putting them away.
I guess the reasoning is, draining them helps to prevent gumming up, but for 3 or 4 months at most, I don't know if it's needed.
« Reply #8 on: February 09, 2017, 09:25:33 PM »
One thing I do with two bikes and much less riding in winter;  I shim up my kickstands and get both bikes almost completely level, with full tanks.  My shed is so tight they cannot fall over.
« Reply #9 on: February 10, 2017, 02:40:12 AM »
+1
