February 12, 2026, 10:43:10 PM *
Author Topic: Hydro lock  (Read 1874 times)
Jym777
Silver Springs Fl
« on: February 16, 2017, 10:08:30 AM »
Hey Guys, I had the old hydro lock on the rt front cyc cleared it and it started right up and sounded fine, thank God! question is have any of you heard of it being a one time deal like something caught in the needle and seat on that carb or am I just hopefully dreaming? Hate the  thought of having to rebuild the carbs and probably the fuel valve also thanks for your opinion guys much appreciated! Jym...
« Reply #1 on: February 16, 2017, 10:34:17 AM »
I can understand your dislike of rebuilding the carbs. The petcock is a piece of cake. But imagine your dislike of replacing the starter gear and possibly rear case. Not to mention having to do the carbs anyway.
« Reply #2 on: February 16, 2017, 12:14:53 PM »
Read this about 10 times. Smiley
bulldog620
Let's take our country back!! Semper Fi
Ellijay, GA
« Reply #3 on: February 16, 2017, 12:24:57 PM »
 Cheesy Cheesy Cheesy
Harryc
Sebastian, Fl
« Reply #4 on: February 16, 2017, 12:29:31 PM »
Reminds me of the old Fram commercials...."You can pay me now, or pay me later". Meathead has it right. I'd also install a Dan-marc  fuel shut off valve for good measure, but that's me.
« Last Edit: February 16, 2017, 12:32:43 PM by Harryc » Logged
« Reply #5 on: February 16, 2017, 02:17:52 PM »
My friend went through the same thought process. Fix it or it will happen again.
« Last Edit: February 16, 2017, 02:39:09 PM by Chrisj CMA » Logged
Jym777
Silver Springs Fl
« Reply #6 on: February 16, 2017, 04:27:38 PM »
Thanks for the input guys, this is really going to test my mechanal ability, sure not looking forward to this one
« Reply #7 on: February 16, 2017, 06:07:13 PM »
Thread hijack.
But what about the oil dripping on your carpet.
Oh......................... never mind it's 2 Valkyries  Evil
N0tac0p
« Reply #8 on: February 23, 2017, 05:32:20 AM »
I thought there was a DAN mark install section in shop talk.  told you what to use so not to starve fuel, where to position for flow, which dan mark to buy......
but don't see it
« Reply #9 on: February 23, 2017, 06:01:15 AM »
Your real problem is with the fuel petcock. This is the issue that needs to be solved.
Regarding the carburetor: You can drain the float bowl or take the float bowl off the offending carburetor to clear any crud that may have caused the needle to malfunction.
Note that as long as your fuel supply is shut off properly you cannot have a hydrolock event.
I don't see where you need to r&r the carburetors simply because the fuel petcock malfunctioned, and besides, the needle valve leaking may simply be a transient event.
Ramie
2001 I/S St. Michael MN
« Reply #10 on: February 23, 2017, 06:39:08 AM »
The Carbs really aren't that hard to do, while your at it desmog so you have more space for the fuel shutoff solenoid.  You can find the float valves on amazon most of the carb gaskets on Redeye Technical and rebuild coverset for the petcock or new pringle shutoff.
« Reply #11 on: February 24, 2017, 01:16:29 PM »
Potentially dangerous to ignore the carb work as part of the repair to prevent another lock. The issue on the bike I fixed was with the float, not the needle valve. If the float/ needle valve are not shutting gas off it would be much easier for it to happen again.
indybobm
Franklin, Indiana VRCC # 5258
« Reply #12 on: February 24, 2017, 01:47:06 PM »
Chrisj, what was wrong with the float?
So many roads, so little time
VRCC # 5258
indybobm
« Reply #13 on: February 24, 2017, 01:52:52 PM »
Jeff, what was wrong with the float?
VRCC # 5258
« Reply #14 on: February 24, 2017, 02:59:51 PM »
The float had deformed just enough so that when it rose up with filling gas it lost contact with the needle valve. We even tested it wit the new needle valves. Absolutely no contact as the bowl got full.
Psychotic Bovine
New Haven, Indianner
« Reply #15 on: February 26, 2017, 04:24:18 PM »
My 2 cents:  Get a Dan Mark fuel cutoff solenoid.  $30 insurance against hydro-lock.
I had my own hydro-lock happen.  We had trailered to Colorado and back and the change in altitude caused the petcock to trigger flooding one cylinder.  Thankfully, it didn't break anything when we tried to start it.
I feel very good about having the electric fuel cutoff.
good info here.
http://www.horseapple.com/Valkyrie/Tech_Tips/Fuel_Shutoff/fuel_shutoff.html
« Last Edit: February 26, 2017, 04:26:03 PM by Psychotic Bovine » Logged
"I aim to misbehave."
Cracker Jack
« Reply #16 on: February 26, 2017, 05:53:25 PM »
good info here.
I don't understand, how can a change in altitude cause the petcock to trigger? Smiley
Psychotic Bovine
« Reply #17 on: February 27, 2017, 04:49:15 AM »
Pressure change.  We went from a high altitude (10,000 feet, lower atmospheric pressure), to a higher pressure at 760 feet.  I suspect that created a pressure differential on the petcock diaphragm and made it leak.  I could be wrong, but that was the only time it had ever done it.
When we took it apart, everything was fine inside.  Adding the fuel solenoid is just added insurance.
Firefighter
Harlingen, Texas
« Reply #18 on: February 27, 2017, 07:37:00 PM »
Always turn the fuel off when hauling your bike on a trailer, back of truck etc. The bouncing will cause any carbureted engine to flood.
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
