February 12, 2026, 10:42:58 PM *
Author Topic: Shifter loose  (Read 995 times)
Jym777
Silver Springs Fl
« on: February 17, 2017, 07:25:52 AM »
I noticed this morning that my shifter arm out of the case was a little sloppy also seeping a little oil I imagine the only fix is to tear down? It sucks only 32800 on the old girl! Any ideas,Thanks
« Reply #1 on: February 17, 2017, 08:00:26 AM »
Do a search on this forum. It's an easy fix.
« Reply #2 on: February 17, 2017, 08:02:15 AM »
You have no problem there. The looseness is typical and the seepage can be corrected with an oil seal.
Gideon
Indianapolis, IN.
« Reply #3 on: February 17, 2017, 09:17:01 AM »
Changing the oil seal is not a big deal.
Daniel Meyer
The State of confusion.
« Reply #4 on: February 17, 2017, 09:24:18 AM »
Yep, they are sloppy.
Here's the oil seal change:
http://lifeisaroad.com/valkshiftseal.html
CUAgain,
Daniel Meyer
Jym777
Silver Springs Fl
« Reply #5 on: February 17, 2017, 03:15:20 PM »
Thanks guys for the info, your the best!!
« Reply #6 on: February 17, 2017, 05:12:49 PM »
As the above, a new seal will go a long way.
That is the design, no reason to worry about it. My one IS at 69K miles is leaking a little. I'll try to fix it before selling.
But if you are one to worry, there is a modification done to the GW GL1500, but again, it isn't a problem that needs to be fixed, so it is more just a waste, but some like the idea of fixing it.
http://goldwingdocs.com/forum/viewtopic.php?f=14&t=19760
I have not heard if it has been modified to work on the Valkyrie, but have never followed up with it, as I'm not interested if it for my Valk.
