February 12, 2026, 10:43:12 PM *
Author Topic: timing rotor thing  (Read 922 times)
Eric58701
Minot NorthDakota
« on: February 17, 2017, 09:00:58 AM »
i have seen talk and mention about a rotor that will advance the timing   anyone run one? i forgot what its actually called sorry
« Reply #1 on: February 17, 2017, 09:47:10 AM »
Trigger Wheel aka TW.
advance base timing 4 degrees. u can modify the OEM which best to do and easy or buy the one www.factorypro.com sells.
« Reply #2 on: February 17, 2017, 05:00:52 PM »
I recall the other method is to put the IS ignition module onto a std/tourer, instead.
There is more to just changing it, so research first. I think you also want a temp sensor.
Eric58701
Minot NorthDakota
« Reply #3 on: February 18, 2017, 05:06:01 AM »
my bike is the 99 interstate
« Reply #4 on: February 18, 2017, 01:11:42 PM »
In that case, I would do a lot more searching. There is a lot posted here on trigger wheels.
No one else posted, so I'll say, I don't recall anything good about using them on an IS. I'm sure someone will post that they have it and it is great. But I would look and see what has been mentioned. I could be wrong, but I have no interest in one, so only have a passing memory of the item.
There is a 4 & 6 degree wheel.
Then isn't there also the potentiometer to manual adjust the timing?
« Last Edit: February 18, 2017, 06:42:00 PM by gordonv » Logged
« Reply #5 on: February 18, 2017, 02:12:15 PM »
then only 4 degrees.
