February 13, 2026, 12:09:57 AM
Fuel pump heat shield
Topic: Fuel pump heat shield (Read 992 times)
February 19, 2017, 02:08:06 PM »
Fabbed up a heat shield out of shop scraps & installed. If it was a problem, as many think including me, it is no more. 16-ga steel plate, 1/2" angle steel.
rhinor61
Northern California
Re: Fuel pump heat shield
February 21, 2017, 01:40:01 PM »
Mark nice work!
You are always coming up with new ways to improve our bikes.
I need one.
John
Northern California
1998 Valkyrie Tourer Black/jade
VRCC #28001
Tfrank59
'98 Tourer
Western Washington
February 23, 2017, 10:13:38 AM »
Yes, nice job. I didn't know that's an issue--is it that road stuff gets up in there and can ruin the pump or hoses?
-Tom
Keep the rubber side down. USMC '78-'84
February 23, 2017, 11:19:40 AM »
Quote from: Tfrank59 on February 23, 2017, 10:13:38 AM
No. It's a HEAT shield. There have been numerous belly tank fuel pump failures. Behavior implies it's likely overheating and there's a huge heat source right next to it - the single wall section of the headers which get red hot if there's insufficient airflow around them. If the problem is caused by heat from the exhaust - this will stop it. I have not had the failure yet - and now I bet I won't going forward.
DarkSideR
Pueblo, Colorado
February 23, 2017, 12:51:49 PM »
I fab'd up a heat shield after my belly tanks fuel pump embarrassingly quit on me at the beginning of a group ride.
I went the other way with the mount. My heat shield mounts under the pump itself so the pump holds the heat shield in place.
If I were to do another one I would build an air scoop to pull air up and over the pump, but I hope just protecting it from the heat from the exhaust pipe will be good enough.
2001 Valkyrie Super Tourer
VRCC#34410
VRCCDS#0263
February 23, 2017, 01:49:12 PM »
As I can't weld, I'd probably make something out of aluminum and use pop rivets if I needed to join parts. No need to paint, and lighter.
Reply #6 on:
February 23, 2017, 02:06:12 PM »
You can "weld" aluminum with just a MAP torch, some aluminum feed rods, and a wire brush. Almost like brazing. No big investment. See
https://www.youtube.com/watch?v=3SBfP4_i1Go
Here's another one. Simple, cheap.
https://www.youtube.com/watch?v=QLAjeSa6CqI
Last Edit: February 23, 2017, 02:18:35 PM by MarkT
