February 12, 2026, 10:44:08 PM *
Author Topic: Rotate throttle  (Read 916 times)
Grandpot
Fort Mill, South Carolina
« on: February 21, 2017, 04:40:56 AM »
Due to interference with the front brake lever and my newly installed heated grips, I need to rotate the throttle housing about 30 degrees.  It looked very simple to do until I removed the two Philips head screws that hold the emergency cut-off switch to the bottom half of the housing.  The bottom half seems to be fastened to the handlebar.  I can't see how it is fastened or where it is fastened.  Anyone have an idea?
The heated grip has been glued on and I don't want to take a chance on damaging it by trying to remove it from the throttle tube.
« Reply #1 on: February 21, 2017, 05:12:22 AM »
There's little pins that register your lever perches and stuff to the
handlebars through little holes in the handlebars... could this be it?
Grandpot
« Reply #2 on: February 21, 2017, 07:02:44 AM »
Mike:
It might be, I just can't see how to get to it.
« Reply #3 on: February 21, 2017, 09:09:47 AM »
Mike:
Just pull the housing out. You will either need to drill a new hole in the bars or grind off the nub on the housing. I think I would go with a new hole.
Harryc
Sebastian, Fl
« Reply #4 on: February 21, 2017, 10:22:00 AM »
That crazy glue dries fast Wink. The instructions probably say to try a dry fit first? If they were Oxford Heated Grips I know the instructions say that. Put them on two bikes so far and it's a good idea to check for any interference between the grips and the controls before gluing things ...
« Last Edit: February 21, 2017, 10:32:51 AM by Harryc » Logged
Grandpot
« Reply #5 on: February 21, 2017, 11:01:45 AM »
Harry, you are absolutely right.  I did a pre-fit and then when I applied the glue I didn't pay attention and put it in the wrong position.
Thank you everyone for the replies.  I'll fix it tonight.
