February 13, 2026, 07:06:03 AM *
Author Topic: Did I prevent myself from switching seats in the future?  (Read 1902 times)
deafen
« on: February 21, 2017, 08:14:13 AM »
While doing my This Is Not A SuperValk conversion, I routed the taillight wires though two underseat threaded holes in the fender that had been covered by stickers.  Thinking about it now, are these seat mounting holes for the Standard/Tourer seat?  I'm thinking about swapping the IS seat for a S/T seat so that I can more easily put a backrest on, but now I'm afraid I've run wires through the mounting holes I need.  Did I mess up?
« Reply #1 on: February 21, 2017, 08:24:36 AM »
Probably so if I understand what you did. I'd just pull those wires back through and run them along the right side of the fender and through a hole used by the other harness that goes through there.
deafen
« Reply #2 on: February 21, 2017, 11:35:16 AM »
I was going to do that, but the grommet was too tight to run three additional wires through.  Not going to do anything for now, but I'll keep in mind that I need to re-route things if I do swap seats.  Thanks!
NewValker
VRCC# 36356
Oxford, MA
« Reply #3 on: February 21, 2017, 03:58:00 PM »
I believe those holes are what the Ultimate King seat's backrest bolts into. Not sure what Honda intended them for originally.
Craig
« Last Edit: February 21, 2017, 04:03:32 PM by NewValker » Logged
Turns out not what or where,
« Reply #4 on: February 21, 2017, 04:48:25 PM »
Pretty sure Mother Honda used the same fenders for all years all models.
« Reply #5 on: February 21, 2017, 06:25:50 PM »
Drill another hole next to it only smaller to accommodate the extra wires you're running. Spray some paint in there to prevent rust then insert a rubber grommet before running the wires.
A trick I've used many times when running wires in tight places....spray some regular rubbing alcohol on the existing wires, really soak it. You'll find your extra wires might just slip through now. It's an old trick I learned many years ago....if you want to move rubber or plastic against anything, especially metal or some other rubber, use alcohol and it makes it slick as snot on a doorknob.  cooldude
saddlebag
« Reply #6 on: February 21, 2017, 06:47:46 PM »
The two threaded holes are to  attach OEM pillion seat on my Tourer.
Participant Southeast Asia War Games
« Reply #7 on: February 21, 2017, 06:49:38 PM »
  Cool tip, I like it.
ridingron
Orlando
« Reply #8 on: February 24, 2017, 09:17:26 PM »
The alcohol also evaporates and doesn't leave a sticky mess.
« Reply #9 on: February 25, 2017, 05:08:17 AM »
Craig
No they are for a 2 piece seat, passenger pillion. The ultimate backrest slides into a slot in the back of the drivers seat.
« Reply #10 on: February 25, 2017, 05:49:54 AM »
Craig
Not on all of them.  Ultimate King Boy back rest bolts in there.
« Reply #11 on: February 25, 2017, 06:02:22 AM »
Craig
I did not know that.  uglystupid2 thought they all slide in. Learn something new everyday.
PAVALKER
Pittsburgh, Pa
« Reply #12 on: February 28, 2017, 08:42:10 AM »
You will need those holes for a rear two piece seat, regardless of brand.   Remove those wires and run them along the original wiring harness path, under the fender.    A stock 2000 Tourer seat set fits nicely on my Interstate and does use those two holes, as would any aftermarket two piece seat set and even the Utopia Rider Backrest..
John
Cueroite
« Reply #13 on: May 01, 2017, 05:58:26 PM »
i recently removed the trunk from my Interstate and noticed that I have no seat stay bracket to hold the back of my seat.  Where can I purchase that bracket and do I need to purchase a touring single or double seat?
« Reply #14 on: May 01, 2017, 06:14:53 PM »
The bracket is part of the fender and if you don't have one, it must have been removed.  It is not a part you can purchase and you'll most likely have to fab something yourself.
Tourer and Standard seats are two parts, rider and passenger.
« Reply #15 on: May 01, 2017, 09:45:22 PM »
The IS goes into a stay that is part of the trunk mount. With the trunk removed, no stay.
I believe you can change out to a std/tourer fender and use the one from there instead.
« Reply #16 on: May 02, 2017, 04:10:18 AM »
My I/S has both the stay in the trunk bracket and the stay on the fender.
I have to place the back of the seat in the back stay and push down on the seat to get the male part on the seat bottom into the stay on the fender.
Kind of a PITA.
Cueroite
« Reply #17 on: May 02, 2017, 04:50:20 AM »
Thanks all for the info.  Hook, can I get a photo of your fender and the bracket?
Bagger John - #3785
« Reply #18 on: May 02, 2017, 01:38:30 PM »
Go order the Std/Tourer taillight harness from Honda (both front and rear sections) then swap out the I/S harness and call it a day.
Works good; lasts long time and IS 'stock'.  Wink
« Reply #19 on: May 02, 2017, 04:36:28 PM »
bzane
« Reply #20 on: May 05, 2017, 08:49:15 PM »
I give up, what IS this picture? From aliens?
« Reply #21 on: May 06, 2017, 07:50:51 PM »
You read the post, right?
